ARC Objects  C# interface featureclass
4554
12-16-2014 09:46 PM
johnkeays
Does anyone have a sample of a simple program to open and add a feature to a featureclass dataset.
Have located a geodatabase in C# but need the right using for featureclass details.
Using ARCGIS online and 10.2.4 sdk for .net and visual studio 2013.
Cheers
John Keays
johnkeays
To Alexander,
Went looking for a way to update ARC objects in ARC MAP for a Local Authority.
Surveyors survey the as constructed data and that is loaded into the ARCMAP
product using GPS coordinates.
Found Don Kuehne ARCGIS to AutoCAD download and it seems to be able to do the
job. Don has some sample code developed for the USA public works meetup. The
routines are open source.
Are ARC objects to be phased out? That came from the ESRI contacts in Brisbane.
Is arc objects still the easiest way to get info to ARCMAP from external sources?
The Local Government defines the fields and records in a schema ADAC.XSD with
about ten associated xsd files. some 1600 fields. What is the best way to copy
the field names from the XSD to a C# structure. How are enums handled.
Keays Software has a product that goes from the XSD to AutoCAD.
Would FME do the job...
Cheers
John Keays
John Keays of Keays Software
PO Box 80, Toowong Qld 4066
Phone 07 3870 1711 fax +61-7-38701784
www.keays.com.au john@keays.com.au
KEAYS SOFTWARE PRIVILEGED PRIVATE AND CONFIDENTIAL - The information contained in
this e-mail and any attachments is confidential and may attract legal privilege.
It is only intended for the named recipient/s. If you are not a named recipient
any use of this information including copying, distribution and publication is
prohibited. Confidentiality and legal privilege are not waived or lost as a
result of mistaken or erroneous delivery. If you are not a named recipient,
please delete all copies immediately and contact the sender to advise of the error.
It is recommended that you scan this email and any attachment before opening.
KEAYS SOFTWARE does not accept any responsibility or liability for loss or damage
arising directly or indirectly from opening this email, opening any attachments
or any communication errors.
On Wed 21/01/15 3:01 AM , Alexander Nohe geonet@esri.com sent:
ARC OBJECTS  C# INTERFACE FEATURECLASS
reply from Alexander Nohe in ArcObjects.NET - View the full
discussion
AlexanderNohe1
Hello John,
Are you trying to add a feature to an online feature or an offline feature?
Thanks!
Alexander
johnkeays
To Alexander,
Cheers
John Keays
discussion
