Hi Alex,
Not sure I'm clear on the issue. The developer subscription is per user, not per machine. If you have a subscription, you are not limited to installing software to only one machine. You ARE limited to that user, you, being the only one to use that installation. So, if you install once for development, you can install on a different machine to test your development. Does that make sense? Maybe I misunderstood this issue.
