ArcGIS Pro Solution Deploy Failed
3465
11
08-29-2017 03:11 PM
EddyClark
No matter which solution I attempt to deploy I get an error.  The error is not very helpful so here I am.  Any suggestions?
solution deploy
CarlosPorras
New Contributor III
I'm also having the same issue with failing to deploy any solution with the tool. Did you find a solution yet?
EddyClark
No.
JennaWalz2
New Contributor II
I am having the same issue! Did you ever figure out a work around?
EddyClark
For the first time I tried again and it worked.  I was having problems with Python that I just couldn't fix, so I deleted my user profile from windows and basically started over fresh.
solutions deploy
RyanPaquette3
New Contributor II
"Unable to initialize. Failed to connect to the source portal. Please ensure you provided the correct url and credentials. Failed to add 'solution name'"
gisadminCPG
New Contributor II
I have the same issue.   Waiting on ESRI Support response.  If I get a resolution I'll try and remember to post
JayJohnsonWashoeCounty
Occasional Contributor III
Did you ever get an ESRI Support response on this?  I'm getting the same exact error message:
#esri solution
Jay
Washoe County GIS
VincentRobinson
New Contributor III
Did you ever get this to work for you?
My workplace has a lot of internet security measures that often cause issues, so I tried deploying from home and had about 50% success.
Finally, I called my regional ESRI rep and he deployed it from within the ESRI mothership.  Said this was a heavy network traffic lift, so it was not unusual to have problems...
Jay
Washoe County GIS
