ArcMap 10.0 SP2ArcObjects Java SDK SP2Eclipse Helios 3.6.2Java sdk 1.6.0_24Following this example: http://help.arcgis.com/en/sdk/10.0/java_ao_adf/conceptualhelp/engine/0001/00010000041v000000.htmI'm finding that using JOptionPane.showMessageDialog's do not always execute right away when you click a tool and sometimes the message dialog opens up behind ArcMap. And don't click on anything else until you've dismissed the dialog or ArcMap hangs.Anyone using Java add-ins? If so, what are you using for notifying the client of certain actions? JOptionPane messages?
import java.awt.event.MouseEvent;
import java.io.IOException;
import java.net.UnknownHostException;
import javax.swing.JOptionPane;
import com.esri.arcgis.addins.desktop.Tool;
import com.esri.arcgis.arcmapui.IMxDocument;
import com.esri.arcgis.carto.IActiveView;
import com.esri.arcgis.display.IDisplayTransformation;
import com.esri.arcgis.display.IScreenDisplay;
import com.esri.arcgis.framework.IApplication;
import com.esri.arcgis.geometry.IPoint;
import com.esri.arcgis.geometry.ISpatialReference;
import com.esri.arcgis.geometry.Point;
import com.esri.arcgis.geometry.SpatialReferenceEnvironment;
import com.esri.arcgis.interop.AutomationException;
public class HelloTool extends Tool {
* Called when the tool is activated by clicking it.
* @exception java.io.IOException if there are interop problems.
* @exception com.esri.arcgis.interop.AutomationException if the component throws an ArcObjects exception.
@Override
public void activate() throws IOException, AutomationException {
// TODO Auto-generated method stub
@Override
public void mousePressed(MouseEvent mouseEvent) {
super.mousePressed(mouseEvent);
try {
Point point1 = new Point();
point1.putCoords((double)mouseEvent.getX(), (double)mouseEvent.getY());
Point point2 = (Point) getMapCoordinatesFromScreenCoordinates(point1,av);
String message2 = "x: " + point2.getX() + " y: " + point2.getY();
Point point3 = (Point) getScreenCoordinatesFromMapCoorindates(point1,av);
String message3 = "x: " + point3.getX() + " y: " + point3.getY();
JOptionPane.showMessageDialog(null, message2, "Map Coordinates from Screen Coordinates", JOptionPane.INFORMATION_MESSAGE);
JOptionPane.showMessageDialog(null, message3, "Screen Coordinates from Map Coordinates", JOptionPane.INFORMATION_MESSAGE);
} catch (UnknownHostException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (IOException e) {
} catch (Exception e) {
private IApplication app;
private String appName;
private IActiveView av;
private int mapUnits = com.esri.arcgis.system.esriUnits.esriFeet;
@Override
public void init(IApplication app){
//Stuff in here runs right away, even if the map document doesn't have the add-in loaded.
this.app = app;
try {
IMxDocument mxDocument = (IMxDocument)app.getDocument();
appName = app.getDocument().getTitle();
av = mxDocument.getActiveView();
} catch (AutomationException e) {
public IPoint getMapCoordinatesFromScreenCoordinates(IPoint screenPoint, IActiveView activeView)throws Exception{
if (screenPoint == null || screenPoint.isEmpty() || activeView == null)
return null;
int nad83HarnAZCentral = com.esri.arcgis.geometry.esriSRProjCSType.esriSRProjCS_NAD1983HARNSPCS_AZCentral;
SpatialReferenceEnvironment spatRef = new SpatialReferenceEnvironment();
ISpatialReference nad83HarnAZC = spatRef.createProjectedCoordinateSystem(nad83HarnAZCentral);
IScreenDisplay screenDisplay = activeView.getScreenDisplay();
IDisplayTransformation displayTransformation = screenDisplay.getDisplayTransformation();
displayTransformation.setSpatialReferenceByRef(nad83HarnAZC);
displayTransformation.setUnits(mapUnits);
return displayTransformation.toMapPoint((int)screenPoint.getX(), (int)
screenPoint.getY());
public IPoint getScreenCoordinatesFromMapCoorindates(IPoint mapPoint, IActiveView activeView)throws Exception{
if (mapPoint == null || mapPoint.isEmpty() || activeView == null)
return null;
int x[] = new int[1];
int y[] = new int[1];
displayTransformation.fromMapPoint(mapPoint, x, y);
IPoint returnPoint = new Point();
returnPoint.putCoords(x[0], y[0]);
return returnPoint;
