I am working on a C# tool that is looping over polygons geometries vertices in order to create a list of deltas (distance) between vertices coordinates. The output is a json that will be consumed by a custom application.
The output is a JSON containing a list of features objects which contains attributes and geometry deltas arrays like this one:
"features": [
"attributes" : {"CD_MUNCP" : 00000, "NOM_MUNCP": "Name1"},
"geometry" : [[5767767, -834778, -10, 199, 99, 332, 9, -9], [5787767, -837709, 123, 33, -31, 121, 0, 12330]]
"attributes" : {"CD_MUNCP" : 00001, "NOM_MUNCP": "Name2"},
"geometry" : [[5784576, -831278, -190, 54, 0, -2, 5464, 789], [57354576, -837008, 66, 872, 3445, -879, -2, 22]]
The geometry deltas output is expected to be on this format: [[x0, y0, (x0-x1), (y0-y1), (x1-x2), (y1-y2)]
Exterior rings and interior rings deltas are on the same level in the array: [[ExteriorRing1 deltas], [InteriorRing1 deltas], [ExteriorRing2 deltas], ...]
I am using deltas instead of absolute coordinates to compact the size of the json output. This method has proven to be able to reduce size by more than 50% for huge geometry.
I am using IEnumerable<> to create the geometry deltas because I thought it would be faster, but it appears this is not really compatible with JSON serialization (it takes very long to serialize) so I transform them using .ToList();
The most important thing with the code is the performance because it aims to be used in a custom GeoProcessing Service on ArcGIS Server.
My tests prove that the bottleneck is the JSON serialization that takes more than 50% of the processing time. For instance for a big FeatureClass it could takes 1.5 seconds to create the deltas but 25 seconds to serialize it to JSON.
Is there some optimizations or workarounds I can do to improve the performance? Any suggestions would be appreciated.
using System;
using System.Collections.Generic;
using fastJSON;
using ESRI.ArcGIS.ADF;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.esriSystem;
namespace DesktopConsoleApplication1
class Program
static void Main(string[] args)
var watch = System.Diagnostics.Stopwatch.StartNew();
Result result = new Result
features = CreateResultFeatures().ToList()
string output = JSON.ToJSON(result);
watch.Stop();
Console.WriteLine(watch.ElapsedMilliseconds);
Console.ReadLine();
public class Result
public IEnumerable<ResultFeature> features { get; set; }
public class ResultFeature
public Dictionary<string, dynamic> attributes { get; set; }
public IEnumerable<IEnumerable<int>> geometry { get; set; }
public static IEnumerable<ResultFeature> CreateResultFeatures()
IWorkspace gdbWorkspace = FileGdbWorkspaceFromPath(@"\\vnageop1\geod\Maxime\test.gdb");
IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)gdbWorkspace;
IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(@"GEO09E04_MUNCP_GEN");
IQueryFilter queryFilter = new QueryFilterClass();
queryFilter.SubFields = "CD_MUNCP, NOM_MUNCP, SHAPE";
int cd_muncp_idx = featureClass.FindField("CD_MUNCP");
int nom_muncp_idx = featureClass.FindField("NOM_MUNCP");
using (ComReleaser comReleaser = new ComReleaser())
IFeatureCursor cursor = featureClass.Search(queryFilter, false);
comReleaser.ManageLifetime(cursor);
IFeature feature = null;
while ((feature = cursor.NextFeature()) != null)
ResultFeature resultFeature = new ResultFeature
attributes = new Dictionary<string,dynamic>
{ "CD_MUNCP", Convert.ToString(feature.Value[cd_muncp_idx]) },
{ "NOM_MUNCP", Convert.ToString(feature.Value[nom_muncp_idx]) }
geometry = PolygonToDeltas(feature.Shape as IPolygon4).ToList()
yield return resultFeature;
public static IEnumerable<IEnumerable<int>> PolygonToDeltas(IPolygon4 polygon)
IGeometryBag exteriorRingGeometryBag = polygon.ExteriorRingBag;
IGeometryCollection exteriorRingGeometryCollection = exteriorRingGeometryBag as IGeometryCollection;
for (int i = 0; i < exteriorRingGeometryCollection.GeometryCount; i++)
IGeometry exteriorRingGeometry = exteriorRingGeometryCollection.get_Geometry(i);
IPointCollection exteriorRingPointCollection = exteriorRingGeometry as IPointCollection;
yield return CreateDeltas(exteriorRingPointCollection);
IGeometryBag interiorRingGeometryBag = polygon.get_InteriorRingBag(exteriorRingGeometry as IRing);
IGeometryCollection interiorRingGeometryCollection = interiorRingGeometryBag as IGeometryCollection;
for (int k = 0; k < interiorRingGeometryCollection.GeometryCount; k++)
IGeometry interiorRingGeometry = interiorRingGeometryCollection.get_Geometry(k);
IPointCollection interiorRingPointCollection = interiorRingGeometry as IPointCollection;
yield return CreateDeltas(interiorRingPointCollection );
private static IEnumerable<int> CreateDeltas(IPointCollection pointCollection)
int previous_x = (int)pointCollection.get_Point(0).X;
int previous_y = (int)pointCollection.get_Point(0).Y;
yield return previous_x;
yield return previous_y;
for (int i = 1; i < pointCollection.PointCount; i++)
int current_x = (int)pointCollection.get_Point(i).X;
int current_y = (int)pointCollection.get_Point(i).Y;
yield return previous_x - current_x;
yield return previous_y - current_y;
previous_x = current_x;
previous_y = current_y;
