'Create a union-ed geometry of all of the features in the layer Dim pFL2 As IFeatureLayer2 = pLayer Dim pFClass As IFeatureClass = pFL2.FeatureClass 'Dim pFLD As IFeatureLayerDefinition = pFL2 'Dim pQF As IQueryFilter = New QueryFilter 'pQF.WhereClause = pFLD.DefinitionExpression Dim pFCursor As IFeatureCursor = pFClass.Search(Nothing, True) 'Replace Nothing with pQF Dim pFeature As IFeature = pFCursor.NextFeature Dim pBag As IGeometryCollection = New GeometryBag Do Until pFeature Is Nothing pBag.AddGeometry(pFeature.Shape, , 0) pFeature = pFCursor.NextFeature Loop
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred...
This Search method will not work on joined fields. If the FeatureLayer has any joins, you should use the IGeoFeatureLayer::SearchDisplayFeatures method instead.
Dim pGFL As IGeoFeatureLayer = pLayer Dim pFCursor As IFeatureCursor = pGFL.SearchDisplayFeatures(Nothing, True)
Dim pFL2 As IFeatureLayer2 = pLayer Dim pFCursor As IFeatureCursor = pFL2.Search(Nothing, True) Dim pFeature As IFeature = pFCursor.NextFeature Dim pBag As IGeometryCollection = New GeometryBag Do Until pFeature Is Nothing pBag.AddGeometry(pFeature.Shape, , 0) pFeature = pFCursor.NextFeature Loop
