Check if file exists
1072
11-06-2012 03:03 PM
StanStas
have 2 parts question. I've file path loaded into textbox by user... I don't know what data type it is (File, mdb or shapefile.. vector or raster...).
1. I'd like to check if that file path exists. I can use System.IO.File.Exists, but it works only for shapefiles.
2. I'd like to add that file into ArcMap if it is possible. I know how to do this with File geodatabase, but again - I don't know what data type it is http://forums.arcgis.com/threads/67004-Get-Data-Type-from-Path?highlight=path
thanks
BruceNielsen
1. Have you tried the Exists geoprocessing tool?
2. Take a look at some of the 'Open...' methods available in the GPUtilities class
BruceNielsen
StanStas
So, problems are solved, thanks a lot Bruce!
1. gp.Exists works nicely
Dim dt As Object = ""
Dim bExists As Boolean = gp.Exists(path, dt)
2. GPUtilities class has AddToMap function
Dim pGPUtil As IGPUtilities
Dim pDataElement As IDataElement
pGPUtil = New GPUtilities
' Add a rasterdataset to the map
pDataElement = New DERasterDataset
pDataElement.CatalogPath = path
pGPUtil.AddToMap(pDataElement, "", False, Nothing)
' Add a featureclass to the map
pDataElement = New DEFeatureClass
