Convert Geomtry to Json
1236
04-14-2022 04:18 AM
mody_buchbinder
Occasional Contributor III
In arcpy you just do geometry.JSON to get the json string for it.
I could not find a simple way to do the same in ArcObjects.
Convert single geometry (not in feature class) into json (or GeoJson) string.
The GeometryEngine in Pro SDK have ExportToJson.
Anybody?
GKmieliauskas
If you use ArcObjects .NET SDK 10.8 you can use JSONConverterGdb class . I don't know if it is available in earlier versions.
Another way is to use .NET serializer:
        public static string To<T>(T obj)
            string retVal = null;
            System.Runtime.Serialization.Json.DataContractJsonSerializer serializer = new System.Runtime.Serialization.Json.DataContractJsonSerializer(obj.GetType());
            using (MemoryStream ms = new MemoryStream())
                serializer.WriteObject(ms, obj);
                retVal = Encoding.Default.GetString(ms.ToArray());
            return retVal;
mody_buchbinder
I will give it a try.
I checked the ArcObjects JSONConverterGdb but as far as I understand it gets a Table and not single geometry. I will have to create a temporary table and gets all the attributes and not only geometry.
Thanks
GKmieliauskas
mody_buchbinder
Here is my final code. The doc's are real bad , no samples and every small change gives catastrophic error with no error message.
Have fun
 private string geo2json(IFeature feature)
            IJSONWriter jsonWriter = new JSONWriterClass();
            jsonWriter.WriteToString();
            IJSONSerializer jsonSerializer = new JSONSerializerGdb();
            IPropertySet props = new PropertySetClass();
            props.SetProperty("Format", "GeoJSON");
            jsonSerializer.InitSerializer(jsonWriter, props);
            ((IExternalSerializerGdb)jsonSerializer).WriteGeometry(null, feature.Shape);
            var geoJson = Encoding.UTF8.GetString(jsonWriter.GetStringBuffer());
            return geoJson;
FredericWalter
New Contributor III
Another way to do the work is to use JSONConverterGeometry:
IJSONConverterGeometry JSONConverterGeometry = new JSONConverterGeometryClass();
IJSONObject JSONGeometry = new JSONObjectClass();
JSONConverterGeometry.QueryJSONGeometry(geometry, true, JSONGeometry);
string strGeometry = JSONGeometry.ToJSONString(null);
Maybe a litlle bit simplier ...
