I am assuming you are talking about ArcMap. You will want to create Add-ins. They are the most convenient way to give people tool bars and other addin functions in ArcMap. You just need to put it out on a shared drive and they just need to connect to that directory. When you need to update it, all you have to do is replace the add-in file and they get the update the next time they start ArcMap. It even continues to work if you upgrade your clients to a new version of ArcMap.
You can learn about this here:
ArcObjects 10 .NET SDK Help
Good Luck
Brent
