Exception access violation while executing Java ArcObject application
7967
06-10-2015 03:44 AM
KevinLECOCQ
New Contributor III
I have developed an visual application using ArcObjects SDK for Java 10.2 which worked well until yesterday.
Since, I'm facing a fatal error (full trace below) while I don't feel I have changed anything.
The crash occurs when a JFrame is created containing a PageLayoutBean, then the JVM calls NativeObjRef.getJdk13WindowsHandleNative(), and then the ntvinv.dll calls Java_com_esri_arcgis_system_EngineInitializer_initLicensing.
According to the description of the file, Ntvinv.dll is 'Native Invocation Library for ArcGIS Java Interop'.
I don't see where licensing could be a problem as ArcMap starts well, and the other ArcObjects calls also work.
I just discovered that there was a similar function available in Java:
public static void initLicensing(int product, String pathToBin)
Initialize the ArcObjects for ArcGIS Server with options optimal for usage in a ArcGIS Server
Maybe parameters are wrong..
Any idea where to look?
The trace:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x7ce71790, pid=3848, tid=6472
# JRE version: 6.0_43-b01
# Java VM: Java HotSpot(TM) Client VM (20.14-b01 mixed mode windows-x86 )
# Problematic frame:
# C  [ntvinv.dll+0x11790]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x0262a800):  JavaThread "main" [_thread_in_native, id=6472, stack(0x00430000,0x00480000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0xbc5bb6fa, EDX=0x0047f51c
ESP=0x0047f3ec, EBP=0x0047f644, ESI=0x0262a928, EDI=0x00000000
EIP=0x7ce71790, EFLAGS=0x00010202
Top of Stack: (sp=0x0047f3ec)
0x0047f3ec:   14864e80 0262a928 14864e80 0047f694
0x0047f3fc:   0047f6a4 0047f660 6a5c2e2e 625c6572
0x0047f40c:   6a5c6e69 2e747761 006c6c64 415c3a43
0x0047f41c:   49476372 65445c53 6f6c6576 4b726570
0x0047f42c:   30317469 6a5c322e 5c617661 5c65726a
0x0047f43c:   5c65726a 5c6e6962 7477616a 6c6c642e
0x0047f44c:   00540000 005904d8 00000000 0262a800
0x0047f45c:   0262b060 00000000 00000007 0047f554
Instructions: (pc=0x7ce71790)
0x7ce71770:   60 90 eb 7c 8b f8 85 ff 75 7a 53 e8 20 fd ff ff
0x7ce71780:   8b d8 8d 94 24 30 01 00 00 2b d3 eb 03 8d 49 00
0x7ce71790:   8a 08 88 0c 02 40 84 c9 75 f6 8d 94 24 30 01 00
0x7ce717a0:   00 52 ff 15 60 90 eb 7c 53 8b f8 e8 88 3f 02 00
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0xbc5bb6fa is an unknown value
EDX=0x0047f51c is pointing into the stack for thread: 0x0262a800
ESP=0x0047f3ec is pointing into the stack for thread: 0x0262a800
EBP=0x0047f644 is pointing into the stack for thread: 0x0262a800
ESI=0x0262a928 is an unknown value
EDI=0x00000000 is an unknown value
Stack: [0x00430000,0x00480000],  sp=0x0047f3ec,  free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [ntvinv.dll+0x11790]  Java_com_esri_arcgis_system_EngineInitializer_initLicensing+0x1020
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  com.esri.arcgis.interop.NativeObjRef.getJdk13WindowsHandleNative(Ljava/awt/Canvas;)J+0
j  com.esri.arcgis.interop.NativeObjRef.a(Ljava/awt/Canvas;)J+1
j  com.esri.arcgis.interop.r.getHandleForCanvas(Ljava/awt/Canvas;)J+1
j  com.esri.arcgis.interop.Ocx.a()J+48
j  com.esri.arcgis.interop.Ocx.addNotify()V+94
j  com.esri.arcgis.controls.PageLayoutControl.addNotify()V+5
j  java.awt.Container.addNotify()V+61
j  javax.swing.JComponent.addNotify()V+1
j  javax.swing.JRootPane.addNotify()V+1
j  java.awt.Window.addNotify()V+73
j  java.awt.Frame.addNotify()V+70
j  java.awt.Window.show()V+8
j  java.awt.Component.show(Z)V+5
j  java.awt.Component.setVisible(Z)V+2
j  java.awt.Window.setVisible(Z)V+2
j  latitude.arcobjects.utils.MapWindow.setPageLayout(Lcom/esri/arcgis/carto/IPageLayout;)V+51
j  latitude.arcobjects.proxy.PageProxy.startVisualMode(Lcom/esri/arcgis/geometry/IEnvelope;)V+20
j  latitude.application.export.Export.main([Ljava/lang/String;)V+2519
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x192f5400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=6220, stack(0x2b5d0000,0x2b620000)]
  0x19352800 JavaThread "AWT-Shutdown" [_thread_blocked, id=5696, stack(0x21870000,0x218c0000)]
  0x19252c00 JavaThread "Thread-3" daemon [_thread_in_native, id=6980, stack(0x1a7f0000,0x1a840000)]
  0x19281000 JavaThread "J-Integra COM initialization thread (please don't touch)" daemon [_thread_blocked, id=468, stack(0x19710000,0x19760000)]
  0x19280800 JavaThread "ArcGIS VisualBean Mode STA Thread" daemon [_thread_in_native, id=2652, stack(0x19680000,0x196d0000)]
  0x1927f800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6760, stack(0x195b0000,0x19600000)]
  0x1927a800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2632, stack(0x19490000,0x194e0000)]
  0x0253f400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3088, stack(0x18cd0000,0x18d20000)]
  0x0253c800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3256, stack(0x18c00000,0x18c50000)]
  0x0253a400 JavaThread "JDWP Command Reader" daemon [_thread_in_native, id=5640, stack(0x18b60000,0x18bb0000)]
  0x02534400 JavaThread "JDWP Event Helper Thread" daemon [_thread_blocked, id=976, stack(0x18b10000,0x18b60000)]
  0x02532000 JavaThread "JDWP Transport Listener: dt_socket" daemon [_thread_blocked, id=700, stack(0x18a30000,0x18a80000)]
  0x02528000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6232, stack(0x188d0000,0x18920000)]
  0x02524c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6240, stack(0x18840000,0x18890000)]
  0x024f5000 JavaThread "Finalizer" daemon [_thread_blocked, id=6616, stack(0x187b0000,0x18800000)]
  0x024f3800 JavaThread "Reference Handler" daemon [_thread_blocked, id=6708, stack(0x18720000,0x18770000)]
=>0x0262a800 JavaThread "main" [_thread_in_native, id=6472, stack(0x00430000,0x00480000)]
Other Threads:
  0x024ef000 VMThread [stack: 0x18690000,0x186e0000] [id=3836]
  0x1917b800 WatcherThread [stack: 0x18d60000,0x18db0000] [id=3320]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation   total 4928K, used 3885K [0x04630000, 0x04b80000, 0x09b80000)
  eden space 4416K,  76% used [0x04630000, 0x0497d6f0, 0x04a80000)
  from space 512K,  98% used [0x04a80000, 0x04afe058, 0x04b00000)
  to   space 512K,   0% used [0x04b00000, 0x04b00000, 0x04b80000)
tenured generation   total 10944K, used 2157K [0x09b80000, 0x0a630000, 0x14630000)
   the space 10944K,  19% used [0x09b80000, 0x09d9b5d8, 0x09d9b600, 0x0a630000)
compacting perm gen  total 16384K, used 16187K [0x14630000, 0x15630000, 0x18630000)
   the space 16384K,  98% used [0x14630000, 0x155fee48, 0x155ff000, 0x15630000)
No shared spaces configured.
Code Cache  [0x02630000, 0x02798000, 0x04630000)
total_blobs=721 nmethods=477 adapters=187 free_code_cache=32092160 largest_free_block=1216
Dynamic libraries:
0x00400000 - 0x00425000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\javaw.exe
0x77240000 - 0x773c0000 C:\Windows\SysWOW64\ntdll.dll
0x75ec0000 - 0x75fd0000 C:\Windows\syswow64\kernel32.dll
0x76100000 - 0x76147000 C:\Windows\syswow64\KERNELBASE.dll
0x76d00000 - 0x76da1000 C:\Windows\syswow64\ADVAPI32.dll
0x76930000 - 0x769dc000 C:\Windows\syswow64\msvcrt.dll
0x76520000 - 0x76539000 C:\Windows\SysWOW64\sechost.dll
0x76bb0000 - 0x76ca0000 C:\Windows\syswow64\RPCRT4.dll
0x74bc0000 - 0x74c20000 C:\Windows\syswow64\SspiCli.dll
0x74bb0000 - 0x74bbc000 C:\Windows\syswow64\CRYPTBASE.dll
0x75d70000 - 0x75e70000 C:\Windows\syswow64\USER32.dll
0x75fd0000 - 0x76060000 C:\Windows\syswow64\GDI32.dll
0x76150000 - 0x7615a000 C:\Windows\syswow64\LPK.dll
0x76060000 - 0x760fd000 C:\Windows\syswow64\USP10.dll
0x769f0000 - 0x76a50000 C:\Windows\system32\IMM32.DLL
0x76540000 - 0x7660c000 C:\Windows\syswow64\MSCTF.dll
0x7c340000 - 0x7c396000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\msvcr71.dll
0x6d8c0000 - 0x6db70000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\client\jvm.dll
0x70500000 - 0x70532000 C:\Windows\system32\WINMM.dll
0x73790000 - 0x737dc000 C:\Windows\system32\apphelp.dll
0x6d870000 - 0x6d87c000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\verify.dll
0x6d3d0000 - 0x6d3ef000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\java.dll
0x6d420000 - 0x6d449000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\jdwp.dll
0x6d740000 - 0x6d746000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\npt.dll
0x6d8b0000 - 0x6d8bf000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\zip.dll
0x6d2b0000 - 0x6d2b7000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\dt_socket.dll
0x75e80000 - 0x75eb5000 C:\Windows\syswow64\WS2_32.dll
0x75e70000 - 0x75e76000 C:\Windows\syswow64\NSI.dll
0x70b50000 - 0x70b60000 C:\Windows\system32\NLAapi.dll
0x70b40000 - 0x70b50000 C:\Windows\system32\napinsp.dll
0x70b20000 - 0x70b32000 C:\Windows\system32\pnrpnsp.dll
0x70db0000 - 0x70dec000 C:\Windows\System32\mswsock.dll
0x73800000 - 0x73844000 C:\Windows\system32\DNSAPI.dll
0x70b10000 - 0x70b18000 C:\Windows\System32\winrnr.dll
0x70ae0000 - 0x70b07000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x769e0000 - 0x769e5000 C:\Windows\syswow64\PSAPI.DLL
0x762c0000 - 0x76317000 C:\Windows\syswow64\SHLWAPI.dll
0x74520000 - 0x7453c000 C:\Windows\system32\IPHLPAPI.DLL
0x74510000 - 0x74517000 C:\Windows\system32\WINNSI.DLL
0x70aa0000 - 0x70ad8000 C:\Windows\System32\fwpuclnt.dll
0x70a90000 - 0x70a96000 C:\Windows\system32\rasadhlp.dll
0x70cb0000 - 0x70cb5000 C:\Windows\System32\wshtcpip.dll
0x6d6b0000 - 0x6d6c3000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\net.dll
0x70a80000 - 0x70a86000 C:\Windows\System32\wship6.dll
0x6d0b0000 - 0x6d1fc000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\awt.dll
0x74a80000 - 0x74ad1000 C:\Windows\system32\WINSPOOL.DRV
0x76160000 - 0x762bc000 C:\Windows\syswow64\ole32.dll
0x71000000 - 0x7119e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18807_none_41e554362bd82458\COMCTL32.dll
0x6f1f0000 - 0x6f203000 C:\Windows\system32\DWMAPI.DLL
0x6ee30000 - 0x6eeb0000 C:\Windows\system32\uxtheme.dll
0x6d2e0000 - 0x6d32f000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\fontmanager.dll
0x7ce60000 - 0x7ced5000 C:\ArcGIS\Desktop10.2\bin\ntvinv.dll
0x76db0000 - 0x76e3f000 C:\Windows\syswow64\OLEAUT32.dll
0x76b20000 - 0x76ba3000 C:\Windows\syswow64\CLBCatQ.DLL
0x71ea0000 - 0x71eb1000 C:\Program Files (x86)\Common Files\ArcGIS\bin\ArcGISVersion.dll
0x64530000 - 0x6455b000 C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.7523_none_51c8dd18bbe8adec\ATL90.DLL
0x644a0000 - 0x6452e000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.7523_none_508f21ccbcbbb7a8\MSVCP90.dll
0x711a0000 - 0x71243000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.7523_none_508f21ccbcbbb7a8\MSVCR90.dll
0x732f0000 - 0x73307000 C:\Windows\system32\CRYPTSP.dll
0x731c0000 - 0x731fb000 C:\Windows\system32\rsaenh.dll
0x73220000 - 0x7322e000 C:\Windows\system32\RpcRtRemote.dll
0x617b0000 - 0x61987000 C:\ARCGIS\DESKTOP10.2\BIN\DADFLib.dll
0x74ae0000 - 0x74ae9000 C:\Windows\system32\VERSION.dll
0x74ff0000 - 0x75c3b000 C:\Windows\syswow64\SHELL32.dll
0x64480000 - 0x64497000 C:\ARCGIS\DESKTOP10.2\BIN\AoInitializer.dll
0x74a10000 - 0x74a20000 C:\ARCGIS\DESKTOP10.2\BIN\AppInitializerLib.dll
0x61510000 - 0x617a2000 C:\ARCGIS\DESKTOP10.2\BIN\AfCore.dll
0x70580000 - 0x70591000 C:\Windows\system32\NETAPI32.dll
0x70570000 - 0x70579000 C:\Windows\system32\netutils.dll
0x70550000 - 0x70569000 C:\Windows\system32\srvcli.dll
0x70540000 - 0x7054f000 C:\Windows\system32\wkscli.dll
0x704e0000 - 0x704f2000 C:\Windows\system32\MPR.dll
0x74d70000 - 0x74deb000 C:\Windows\syswow64\COMDLG32.dll
0x61060000 - 0x61501000 C:\ARCGIS\DESKTOP10.2\BIN\AfCore_libFNP.dll
0x72d10000 - 0x72d19000 C:\Windows\system32\snmpapi.dll
0x76320000 - 0x764bd000 C:\Windows\syswow64\SETUPAPI.dll
0x76900000 - 0x76927000 C:\Windows\syswow64\CFGMGR32.dll
0x76a70000 - 0x76a82000 C:\Windows\syswow64\DEVOBJ.dll
0x74560000 - 0x74567000 C:\Windows\system32\WSOCK32.dll
0x72be0000 - 0x72c1c000 C:\Windows\system32\OLEACC.dll
0x6f140000 - 0x6f14a000 C:\Windows\system32\wbem\wbemprox.dll
0x6f150000 - 0x6f1ac000 C:\Windows\system32\wbemcomn.dll
0x6f050000 - 0x6f05f000 C:\Windows\system32\wbem\wbemsvc.dll
0x6ef70000 - 0x6f006000 C:\Windows\system32\wbem\fastprox.dll
0x6ef50000 - 0x6ef68000 C:\Windows\system32\NTDSAPI.dll
0x76680000 - 0x766af000 C:\Windows\syswow64\WINTRUST.dll
0x75c40000 - 0x75d61000 C:\Windows\syswow64\CRYPT32.dll
0x766b0000 - 0x766bc000 C:\Windows\syswow64\MSASN1.dll
0x728b0000 - 0x728b3000 C:\Windows\system32\icmp.Dll
0x70b90000 - 0x70b9d000 C:\Windows\system32\dhcpcsvc6.DLL
0x70b70000 - 0x70b82000 C:\Windows\system32\dhcpcsvc.DLL
0x6d590000 - 0x6d5ac000 c:\arcgis\desktop10.2\bin\ccjw.dll
0x60ed0000 - 0x61060000 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18834_none_72d38c5186679d48\gdiplus.dll
0x7e690000 - 0x7e69f000 c:\arcgis\desktop10.2\bin\reghelp.dll
0x64390000 - 0x6447a000 C:\ARCGIS\DESKTOP10.2\BIN\BGLAPI.dll
0x60e00000 - 0x60ec6000 C:\ARCGIS\DESKTOP10.2\BIN\BGLGeomChestLib.dll
0x72830000 - 0x728a9000 C:\Windows\system32\mscms.dll
0x76a50000 - 0x76a67000 C:\Windows\syswow64\USERENV.dll
0x76670000 - 0x7667b000 C:\Windows\syswow64\profapi.dll
0x7a130000 - 0x7a180000 C:\ARCGIS\DESKTOP10.2\BIN\LCMS117LIB.DLL
0x60d20000 - 0x60df2000 C:\ARCGIS\DESKTOP10.2\BIN\BGLFontEngine.dll
0x79540000 - 0x7965f000 C:\ARCGIS\DESKTOP10.2\BIN\icuuc44.dll
0x781d0000 - 0x79011000 C:\ARCGIS\DESKTOP10.2\BIN\icudt44.dll
0x79350000 - 0x79383000 C:\ARCGIS\DESKTOP10.2\BIN\icule44.dll
0x64360000 - 0x6438f000 C:\ARCGIS\DESKTOP10.2\BIN\BGLAPILib.dll
0x60c80000 - 0x60d1f000 C:\ARCGIS\DESKTOP10.2\BIN\ImageAccessLib.dll
0x60be0000 - 0x60c73000 C:\ARCGIS\DESKTOP10.2\BIN\BGLRasterizerLib.dll
0x79300000 - 0x7930f000 C:\ARCGIS\DESKTOP10.2\BIN\icuio44.dll
0x79160000 - 0x792e5000 C:\ARCGIS\DESKTOP10.2\BIN\icuin44.dll
0x73610000 - 0x73705000 C:\Windows\system32\propsys.dll
0x74a50000 - 0x74a71000 C:\Windows\system32\ntmarta.dll
0x76cb0000 - 0x76cf5000 C:\Windows\syswow64\WLDAP32.dll
0x60b60000 - 0x60bd6000 C:\ARCGIS\DESKTOP10.2\BIN\BGLToGDIHelper.dll
0x64330000 - 0x64358000 C:\ARCGIS\DESKTOP10.2\BIN\BGLSymbolsLib.dll
0x60ab0000 - 0x60b5c000 C:\ARCGIS\DESKTOP10.2\BIN\BGLImageCoders.dll
0x637f0000 - 0x63828000 C:\Windows\system32\icm32.dll
0x60950000 - 0x60aa7000 C:\Windows\System32\msxml6.dll
0x60900000 - 0x60944000 C:\ARCGIS\DESKTOP10.2\BIN\BGLCache.dll
0x60620000 - 0x608f6000 C:\ARCGIS\DESKTOP10.2\BIN\Geometry.dll
0x605f0000 - 0x60612000 C:\Windows\system32\GLU32.dll
0x60520000 - 0x605e8000 C:\Windows\system32\OPENGL32.dll
0x60430000 - 0x60517000 C:\Windows\system32\DDRAW.dll
0x71de0000 - 0x71de6000 C:\Windows\system32\DCIMAN32.dll
0x7d3a0000 - 0x7d79b000 C:\ARCGIS\DESKTOP10.2\BIN\pe.dll
0x1c350000 - 0x1c3ad000 C:\ARCGIS\DESKTOP10.2\BIN\sg.dll
0x60220000 - 0x60425000 C:\ARCGIS\DESKTOP10.2\BIN\ExtTopoEngine.dll
0x1d060000 - 0x1d4be000 C:\ARCGIS\DESKTOP10.2\BIN\sde.dll
0x6f3d0000 - 0x6f3df000 C:\Windows\system32\SAMCLI.DLL
VM Arguments:
jvm_args: -agentlib:jdwp=transport=dt_socket,suspend=y,address=localhost:49309 -Dfile.encoding=Cp1252
java_command: latitude.application.export.Export
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Python27\ArcGIS10.2\;C:\ARCGIS\DESKTOP10.2\BIN;C:\ArcGIS\DeveloperKit10.2\java\jre\bin;C:\PROGRA~2\Fiery\COMMAN~1\plugins;C:\PROGRA~2\COMMON~1\EFI;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Perl64\site\bin;C:\Perl64\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\apache-maven-3.2.1\bin;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\;C:\Program Files\nodejs\;C:\Python27\ArcGISx6410.2;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\Git\cmd;C:\Program Files (x86)\GeoConcept SA\GeoConcept;C:\Program Files (x86)\GeoConcept SA\GeoLib\Data;C:\Program Files (x86)\GeoConcept SA\GeoConcept;C:\Users\Kevin\AppData\Roaming\npm;C:\MinGW\bin;C:\Program Files (x86)\Inkscape
USERNAME=Kevin
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 60 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 8322424k(5368132k free), swap 16643012k(13279444k free)
vm_info: Java HotSpot(TM) Client VM (20.14-b01) for windows-x86 JRE (1.6.0_43-b01), built on Mar  1 2013 02:51:23 by "java_re" with MS VC++ 7.1 (VS2003)
time: Wed Jun 10 11:52:47 2015
elapsed time: 98 seconds
KevinLECOCQ
New Contributor III
For information, I run the program from Eclipse but the error also occurs running outside.
Is there any configuration used by this ntvinv.dll such as registry key or environment variable?
This problem is very blocking for me, so I would be very grateful to get any help.
KwasiAsante1
New Contributor III
Hi Kevin,
try running the application with the following vm argument, -Xss2m; if you still see the crash try increasing the size value
BatbayarBazarragchaa
New Contributor III
Try increasing JVM heap size like following:
-J-Xss4m -J-Xms128m -J-Xmx768m
