Exporting a PDF
220
01-10-2012 01:52 PM
BrianGustafson
I have a WCF service that exports a PDF of a map.  When I run the service locally it works fine.  When I run the service hosted on IIS then I get an error "Cannot create export file. Either file is already open or not enough disk space.  at ESRI.ArcGIS.Output.ExportPDFClass.FinishExporting()".  Is there some setting that I need to change in order to export PDFs?
