Getting error while loading featureclass(branch versioned) in Arcobjects project console app
1244
5
12-05-2022 01:04 AM
shamnasPC
Hi
I have migrated and geodatabase from 10.4 to 10.9.1 to implement branch versioning, Now I am getting error while loading Feature class using Arcobjects using 'IFeatureClass landFc = featureClasses.OpenFeatureClass("FeatureClassName");'. However for other layers(without branch versioning) is working fine. Can help to find a solution to read and query branch versioned Feature classes in arcobjects ?
shamnas
GKmieliauskas
Check the fully qualified featureclass name as written here:
https://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#IFeatureWorkspace_OpenFeatureClass....
Share your error message when open featureclass to get real answer.
shamnasPC
The error is "Unspecified error"
Please note the Feature Dataset is registered as branch version with geodatabase 10.9
Shamnas
GKmieliauskas
Do you use IVersionedWorkspace and IVersion to open FeatureClass?
Look here for sample:
https://gis.stackexchange.com/questions/368914/esri-arcobjects-getting-geometry-directly-from-shape-...
sjones_esriau
ArcObjects does not support Branch Versioning.
There are some other limitations you should be aware of:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/versioning-types.htm
shamnasPC
Thanks @sjones_esriau
So will it work if I use ArcPro sdk to process the branch versioned Data ?  Can suggest a best approach to process branch version data in a batch job ?
