How do I disconnect an open SDE direct connection?
6643
8
06-18-2014 01:07 PM
DavidWatkins2
I am working in an enterprise geodatabase in through Citrix - both the desktop client and SDE (Oracle 11g) are at 10.1.
I often have multiple SDE connections open in ArcCatalog and would like a way to close all of them at once rather than right clicking on each one and selecting disconnect. I don't see any close or disconnect methods and the 'ClearWorkspaceCache_management' method does not close the connection in the ArcCatalog tree.
Does anyone know if there is a way to do this using ArcObjects?
Thank you
AhmedEl-Sisi
Hello David,
I have implemented a method which will loop over a folder contents (selected folder or specific folder name) and close all active database connections inside it.
    private void DisconnectActiveSDEConnections(IGxApplication gxApp, bool useSelectedFolder = false, string folderName = "Database Connections")
            IGxCatalog gxCatalog = gxApp.Catalog;
            object connectionsFolder = null;
            IGxSelection gxSel = null;
            IGxObject gxObj = null;
            int numFound;
            try
                if (useSelectedFolder)
                    gxSel = gxApp.Selection;
                    gxObj = gxSel.Location;
                else
                    connectionsFolder = gxCatalog.GetObjectFromFullName(folderName, out numFound);
                    if (numFound != 1 || connectionsFolder == null)
                        MessageBox.Show("Folder not found!");
                        return;
                    gxObj = connectionsFolder as IGxObject;
                if (gxObj is IGxObjectContainer)
                    IGxObjectContainer gxObjCont = null;
                    IEnumGxObject gxEnum = null;
                    IGxObject gxObject = null;
                    IGxDatabase2 gxDatabase = null;
                    gxObjCont = gxObj as IGxObjectContainer;
                    gxEnum = gxObjCont.Children; //enumerate folder contents
                    gxObject = gxEnum.Next();
                    while (gxObject != null)
                        gxDatabase = gxObject as IGxDatabase2;
                        Debug.Print(gxObject.Category);
                        if (gxDatabase != null && gxDatabase.IsConnected)
                            gxDatabase.Disconnect();
                              Debug.Print(gxObject.FullName + " Disconnected");
            catch (Exception ex)
                MessageBox.Show(ex.ToString());
Regards,
Ahmed
DavidWatkins2
Ahmed,
I tried that solution and it worked perfectly. It did exactly what I wanted. Thank you for sharing with me.
Dave
TracieStreltzer
Anyone figured out a way to do this in python instead?
TomGeo
What if you try it in Python in a 'with' environment? Files and alike are usually closed when leaving the environment. Close is basically invoked.
Don't know if it works with an SDE connection the same way...
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
AsrujitSengupta
Regular Contributor III
TracieStreltzer
Thanks - yes, I had found this solution for the actual disconnect,, but I have 30 databases.  I would like to be able to cycle through a list of connection files in a folder and disconnect all users in each connection file prior to upgrading and restarting servers, etc.  I had an ArcSDE command line to do this on Unix, but since that is going away I'd like to replace it with something I can mange with Python that can do both SQL Server and Oracle instances.. Otherwise I may have to use Poewershell to manage this portion of the script...just wondering if anyone else had worked this out yet...
AhmedEl-Sisi
By following the steps in this post I can run my ArcObjects code inside a python script from Arcmap,
I just rewrite part of the disconnect snippet as a POC and tested it from Arcmap python window and from toolbox and it woks fine.
def ArcCatalog_DisconnectSDEConnections():
    GetDesktopModules()
    pApp = GetCurrentApp()
    import comtypes.gen.esriFramework as esriFramework
    import comtypes.gen.esriCatalogUI as esriCatalogUI
    import comtypes.gen.esriCatalog as esriCatalog
    pGxApp = CType(pApp, esriCatalogUI.IGxApplication)
    print pGxApp
    pGxObj = pGxApp.SelectedObject
    if not pGxObj:
        print "Nothing selected."
        return
    pGxContainer = CType(pGxObj, esriCatalog.IGxObjectContainer)
    if not pGxContainer:
        print "No folder selected."
        return
    pgxEnum =CType(pGxContainer.Children,esriCatalog.IEnumGxObject)
    gxObject =CType(pgxEnum.Next(),esriCatalog.IGxObject)
    while gxObject:
        gxDatabase = CType(gxObject,esriCatalog.IGxDatabase)
        #print gxDatabase.IsConnected
        if gxDatabase and gxDatabase.IsConnected:
            print gxObject.FullName + " Disconnected"
I'm using Arcmap 10.2.1, I added the code to the 10.2 snippets file and called it directly after importing the file.
import arcpy
import sys
sys.path.append(r'FOLDER_CONTAINS_SNIPPET_FILE')
from Snippets import ArcCatalog_DisconnectSDEConnections
try:
except:
    arcpy.AddMessage(sys.exc_info())
You should check "Run Python script in process" checkbox in script properties to get it works.
Hope this approach helps.
TracieStreltzer
That’s great, thank you!!!
Tracie
Tracie Streltzer
GIS Application Administrator - Lead
South Florida Water Management District
561.682.6134 | tstrelt@sfwmd.gov<mailto:tstrelt@sfwmd.gov>
