How draw a circle arc into a srcreendisplay
2170
08-03-2011 06:28 AM
eddixoncastillo
What's wrog with this code?.....
IPoint from = arcPoints["from"] as IPoint;
IPoint to = arcPoints["to"] as IPoint;
IPoint thru = arcPoints["thru"] as IPoint;
ICircularArc circularArcThreePoint = new CircularArcClass();
IConstructCircularArc construtionCircularArc = circularArcThreePoint as IConstructCircularArc;
construtionCircularArc.ConstructThreePoints(from, thru, to, true);
IScreenDisplay screenDisplay = m_mapControl.ActiveView.ScreenDisplay;
ESRI.ArcGIS.Display.ISimpleFillSymbol simpleFillSymbol = new ESRI.ArcGIS.Display.SimpleFillSymbolClass();
ESRI.ArcGIS.Display.ISymbol symbol = simpleFillSymbol as ESRI.ArcGIS.Display.ISymbol;
ESRI.ArcGIS.Display.IRubberBand rubberBand = new ESRI.ArcGIS.Display.RubberPolygonClass();
screenDisplay.StartDrawing(screenDisplay.hDC, (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache);
ISegment pSeg;
ISegmentCollection polyline;
pSeg = circularArcThreePoint as ISegment;
polyline = new PolylineClass();
polyline.AddSegment(pSeg);
screenDisplay.DrawPolyline(polyline as IGeometry);
screenDisplay.FinishDrawing();
A try draw an arc circle, and then store in a new feature, but throw the following exception:
COMException was unhandled by user code
DubravkoAntonic
You need to specify screenDisplay.SetSymbol before Draw method.
But you didn't specified your symbol line and color.
Here is DrawPolyline snippet from help ISymbol Desktop SDK
IScreenDisplay screenDisplay = activeView.ScreenDisplay;     // Constant
(System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache); // Explicit Cast
ESRI.ArcGIS.Display.IRgbColor rgbColor = new ESRI.ArcGIS.Display.RgbColorClass();
rgbColor.Red = 255;
ESRI.ArcGIS.Display.IColor color = rgbColor;
// Implicit Cast
ESRI.ArcGIS.Display.ISimpleLineSymbol simpleLineSymbol = new ESRI.ArcGIS.Display.SimpleLineSymbolClass();   simpleLineSymbol.Color = color;
ESRI.ArcGIS.Display.ISymbol symbol = (ESRI.ArcGIS.Display.ISymbol)simpleLineSymbol;
// Explicit Cast
ESRI.ArcGIS.Display.IRubberBand rubberBand = new ESRI.ArcGIS.Display.RubberLineClass();
ESRI.ArcGIS.Geometry.IGeometry geometry = rubberBand.TrackNew(screenDisplay, symbol);
screenDisplay.SetSymbol(symbol);
screenDisplay.DrawPolyline(geometry);
Hope it helps
eddixoncastillo
don't work !!!!
Especifically i have to draw circles ( or arc circles)...
here my code:
rgbColor.Red = 255;
ESRI.ArcGIS.Display.IColor color = rgbColor; // Implicit Cast
ESRI.ArcGIS.Display.IRubberBand rubberBand = new ESRI.ArcGIS.Display.RubberCircleClass();
IGeometry circulo1;
circulo1 = rubberBand.TrackNew(screenDisplay, symbol);
screenDisplay.DrawPolygon(circulo1);
DubravkoAntonic
Yes it works:), I tried it and it does draw. Put the code in the event OmMouseDown and it will draw rubberband segments on each mouseDown
I wrote this one and it also works in  the same OnMouseDown. Just uncomment DrawPolyline or DrawPolygon and change something to get what you need.
public void DrawSomethingElse(IPoint pPoint)
        {[INDENT]             try
            {[INDENT]                 IPoint a = new PointClass();
                IPoint b = new PointClass();
                a.PutCoords(pPoint.X + 100, pPoint.Y + 100);
                b.PutCoords(pPoint.X - 100, pPoint.Y + 100);
                IScreenDisplay screenDisplay = Extension.ActiveView.ScreenDisplay;     // Constant
                rgbColor.Red = 255;
                ISimpleLineSymbol simpleLineSymbol = new SimpleLineSymbolClass();
                simpleLineSymbol.Width = 3;
                ISimpleMarkerSymbol simpleMarkerSymbol = new SimpleMarkerSymbolClass();
                simpleMarkerSymbol.Color = color;
                ISimpleFillSymbol simpleFillSymbol = new SimpleFillSymbolClass();
                simpleFillSymbol.Color = color;
                construtionCircularArc.ConstructThreePoints(a, pPoint, b, true);
                object missing = Type.Missing;
                ISymbol symbol = (ESRI.ArcGIS.Display.ISymbol)simpleMarkerSymbol;
                // point
                screenDisplay.DrawPoint(a);
                screenDisplay.DrawPoint(b);
                screenDisplay.DrawPoint(pPoint);
                // polygon
                ISegment pSegment = circularArcThreePoint as ISegment;
                ISegmentCollection pSegColl = new PolygonClass();
                pSegColl.AddSegment(pSegment, ref missing, ref missing);
                IGeometry pGeometry = pSegColl as IGeometry;
                symbol = (ESRI.ArcGIS.Display.ISymbol)simpleFillSymbol;
                //screenDisplay.DrawPolygon(pGeometry);
                // poyline
                ISegment pLineSegment = circularArcThreePoint as ISegment;
                ISegmentCollection pLineSegColl = new PolylineClass();
                pLineSegColl.AddSegment(pLineSegment, ref missing, ref missing);
                IGeometry pPolylineGeometry = pLineSegColl as IGeometry;
                //screenDisplay.DrawPolyline(pPolylineGeometry);
[/INDENT]}
            catch (Exception ex)
            {[INDENT]                 MessageBox.Show(ex.Message);
[/INDENT]}
[/INDENT]}
Hope this will be helpful
regards Dubravko Antoni�?
eddixoncastillo
Thank you!!!! It's usefulll
