how to set my own properties to map document using arcobjects
2827
08-14-2015 02:35 AM
Amarchalla
How do i create and set my own properties to map document ??
Just like "ILayerExtensions" which is used to extend the layer's behavior.
can i have similar interface in map document also? just want to extend the map document behaviour.
Thank You.
Amarnath Challa
ModyBuchbinder
Hi
You can use IDocumentInfo2 to enter some MetaData on MXD.
Have fun
Mody
DuncanHornby
MVP Notable Contributor
There is also the IDocumentInfo3 Interface which has even more properties to play with!
