Insert Fails at 1000 records
2523
5
06-11-2010 10:34 AM
MichaelFischer
I'm trying to insert a number of points into an ArcSDE 9.3.1 gdb, in an edit session
I've found that at 1000 features, I get an exception  HRESULT: 0x8005018B
This only happens on SDE .. a personal GDB is fine.
I've tried flushing the load cursor at 500 record intervals, but no difference.
Any ideas?
AlexanderGray
Right off the bat seems like a problem with SDE or the RDBMS.  Sounds like there is a buffer or temp table filling up or that has a max set on it.   I am not really an SDE or Oracle guru but I would look in that direction.
KirkKuykendall
are you doing your inserts between IEditor.StartOperation and IEditor.StopOperation?
JamesGonsoski
It may or may not have anything to do with your issue, but check this help page on ArcSDE Initialization Parameters. Note the default size of the AUTOCOMMIT value.
JohnHauck
What type of underlying database? Is SDE also at 9.3.1? Can you post some example code? I tried a quick test with SQL Express and didn't see a problem with inserting 100,000 features.
RemigijusPankevicius
Must be that Oracle AUTOCOMMIT that is 1000 by default.
http://proceedings.esri.com/library/userconf/proc01/professional/papers/pap869/p869.htm
I've seen examples how to do that bulk inserts without DB tuning, at the cost of leaving transaction.
