Label Polygon corner /vertices coordinate  as graphic
2934
08-30-2014 11:35 AM
NajdALHanahnah
New Contributor III
Dear All
I am working now on ArcObject .Net to develop an gis application , i need your help in certain area , i can now get Polygon corner (vertices ) but how i can show the corner /vertices as graphic with it's label .
Thanks
NajdALHanahnah
New Contributor III
any help or advice Plz.
NajdALHanahnah
New Contributor III
This what i meant :
RiyasDeen
Occasional Contributor III
Hi Najad,
Have look at AddTextElement method in this sample ArcObjects 10 .NET SDK Help .
Iterate through your polygon vertices by casting it as IPointCollection to get vertex geometry.
RavishankarJayaraman
New Contributor II
Here is a small piece of code that does what you need.  The code should work as it is pretty simple and I have not tested even for compilation. But this should get you started with ArcObjects.
//Get the Polygon from the Feature.Shape property
public void AddPolygonVertexText(IMap map, IPolygon polygon)
  IPointCollection ptCollection = (IPointCollection)polygon;
  IPoint outPoint=new PointClass();
  IGraphicsContainer graphicsContainer = map as IGraphicsContainer;
  IElement txtElement=null;
  for(int ptCount=0;ptCount<ptCollection.PointCount;ptCount++)
  ptCollection.QueryPoint(ptCount,outPoint);
  GetTextElement(outPoint,ptCount+1);
  graphicsContainer.AddElement(element, 0);
  ((IActiveView)map).PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
//Creates a TextElement and sends the result to the calling class
private ITextElement AddTextElement(IPoint pt,string labelTxt)
  IElement element = new TextElementClass();
  ITextElement textElement = element as ITextElement;
  IPoint point = new PointClass();
    point.X = pt.X;
    point.Y = pt.Y;
    element.Geometry = point;
    textElement.Text = labelText;
  return textElement;
