Open new ArcMap instance from ArcMap addin form
2240
08-11-2011 02:47 PM
OlwynBruce
New Contributor III
Hi there,
I'm trying to create a new ArcMap instance (ie. open a map in a separate ArcMap window) once a user clicks a button on an addin form.
I can get the map to open - but it's in the same ArcMap window (see code below).
        Dim mApp As ESRI.ArcGIS.Framework.IApplication
        Dim mDoc As ESRI.ArcGIS.Framework.IDocument
        mDoc = My.ArcMap.Application.Document
        mApp = mDoc.Parent
        mApp.Visible = True
        mApp.NewDocument(False, <file>)
How do I get the map to open in a new ArcMap window? I'm using ArcMap 10 and Visual Basic Express .NET 2008 SP1.
Cheers,
Olwyn
BerendVeldkamp
Occasional Contributor II
I'm not sure, but does IAppRot.Add do what you want? Otherwise you could probably just start a new arcmap.exe process by calling Proces.Start("c:\path\to\arcmap.exe") and then get a reference to the new instance using IAppRot. Or save a new mxd and open that: Proces.Start("c:\path\to\mymxd.mxd")
OlwynBruce
New Contributor III
Process.Start("path\to\mxd") totally worked! Thank you very much!!!
