Partial Refresh doesn't work as described
3811
03-02-2011 10:31 PM
LionelMartz
New Contributor II
Hallo again,
know I am challanging another Problem.
I would like to refresh a little feature within the Map. I followed this Guide: http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//000100000242000000
Now I have a big resource of different trys to let ArcMap do what I want. but...
my favorite was:
_activeView.PartialRefresh(esriViewDrawPhase.esriViewGeography, featurelayer, envelope)
In all my trys i just had two different kinds of results:
1. Everything within the envelope has been refreshed (every layer)
2. <nothing happens>
By Googling the problem i found another Post describing the same thing:
http://forums.esri.com/Thread.asp?c=159&f=1707&t=180719
But the Solution is not what i expected.
I hope somone knows a practical solution
ScottMcNeil
I have run into this problem as well.  I stumbled into it trying to redraw polylines on the map.
Here is the thread I started.
http://forums.arcgis.com/threads/32810
I have two problems using this approach.  1) often a layer's previous contents are left on the map (not removed), and 2) periodically, the entire map is repainted for no apparent reason...
If I slow down my updates, I can make the first problem go away (not a practical solution for the real world...).  The second problem occurs regardless of how fast or slow I send my updates.
MiriRevivo
There is an open bug at ESRI regarding this issue - partial refresh actually refreshes all layers instead of taking the given parameters into consideration. It is open since version 9.3.1 but occurs also with 10.0.
I managed to work around the problem in one of our clients' application by using IViewRefresh::AnimationRefresh.
AlexanderGray
Occasional Contributor III
Any hope this will ever be fixed.  Tried in 10.2 same things, everything refreshed.
