I have encountered the same error in the same module when trying to load an MXD created by 9.3.1. The error is:
Problem signature:
Problem Event Name: BEX
Application Name: ArcMap.exe
Application Version: 10.0.2.3200
Application Timestamp: 4d9bad9f
Fault Module Name: RasterIO.dll
Fault Module Version: 10.0.2.3200
Fault Module Timestamp: 4d9b750a
Exception Offset: 00029966
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 74e1
Additional Information 2: 74e15f4f78a355b516e5b2310fdbf823
Additional Information 3: 35e3
Additional Information 4: 35e3ee204c726c40df39cbfda05d377e
This error causes ArcMap, ArcCatalog and, unbelievably, even the MXD program to crash. I've attached the MXD with the problem. I know that other people have had similar errors caused by spaces in raster names but I don't think I have this problem (although I can't check because I no longer have access to 9.3.1 so I have no way of opening the file).
Can anyone help? Are there any plans to fix the problems in this module?
Paul
