Row Deleting Problem
660
6
07-24-2013 06:20 AM
AbdulrahmanAlqasim
Hi
simply, i want to delete a row from a table. the following code works well . however, after deleting , when i open the attribute table , i can see the row still exists and is not deleted. whene i close Arcmap and start it again , open attribute table, the row is not there.
can any please please guide me to deletion method that works directly with no need to restart arcmap.
thank you
                        IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)dataset.Workspace;
                        workspaceEdit.StartEditing(true);
                        // Start an edit operation and create a cursor.
                        workspaceEdit.StartEditOperation();
                        IRow selectedRow = getSelectedRow();
                        selectedRow.Delete();
                        Marshal.ReleaseComObject(featureCursor);
                        // Stop the edit operation.
                        workspaceEdit.StopEditOperation();
                        // Stop the edit session.
                        workspaceEdit.StopEditing(true);
LeoDonahue
Try calling updateContents() on the mxDocument.
AbdulrahmanAlqasim
hi ldonahue
i just tried that but didn't help.
LeoDonahue
post your code please.
RichardWatson
I am not saying that this is your problem but we reported the following problem:
NIM086472
Calling ITable::GetRow during an edit session returns a row that has been deleted.
We were also issued a hotfix/QFE for this issue on 10.1 SP1.
ESRI reported to us that the problem is fixed in 10.2 (which I believe was released this week).
AbdulrahmanAlqasim
after long debugging session , i found out that i have to release the cursor inside getSelectedRow() method
Marshal.ReleaseComObject(pFtrCsr1)
thank you guys for trying help me. i appreciate that
LeoDonahue
Glad you figured it out.  However...
"Marshal.ReleaseComObject(pFtrCsr1)"
That doesn't help anyone in the future figure out what you did.  Your existing code sample does not show where that line is or what pFtrCsr1 is.  If you want to help others, post a more complete example.
