Margo:I put together a quick Console Application to test your MapServer Spatial Query. I was able to get it to work with the following code ... (I apologize that it is in C# instead of VB.NET ... I can convert it if necessary)
IPropertySet connProps = new PropertySet();
connProps.SetProperty("Url", "http://www3.multco.us/ArcGIS/Services");
AGSServerConnectionFactory agsSCFac = new AGSServerConnectionFactory();
IAGSServerConnection agsSConn = agsSCFac.Open(connProps, 0);
IAGSEnumServerObjectName pEnum = agsSConn.ServerObjectNames;
IAGSServerObjectName pSOName = pEnum.Next();
while (pSOName != null)
Console.WriteLine(pSOName.Name);
if (pSOName.Name.Equals("BaseMap/Taxlots")) break;
if (pSOName != null)
IName pName = pSOName as IName;
IMapServer pMapServer = pName.Open();
IMapServerInfo pMapServerInfo = pMapServer.GetServerInfo(pMapServer.DefaultMapName);
IMapDescription pMD = pMapServerInfo.DefaultMapDescription;
IPoint pnt = new Point();
pnt.SpatialReference = pMD.SpatialReference;
pnt.PutCoords(7682600.809, 681343.674);
ISpatialFilter pSpatFilter = new SpatialFilter();
pSpatFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects;
pSpatFilter.Geometry = pnt;
pSpatFilter.WhereClause = "PROPID = 'R311157'";
IRecordSet records = pMapServer.QueryFeatureData(pMD.Name, 0, pSpatFilter);
Console.WriteLine("Found " + records.Table.RowCount(null) + " records");
ICursor pCur = records.get_Cursor(true);
IFeature pFeat = pCur.NextRow() as IFeature;
if (pFeat != null)
Console.WriteLine("SUCCESS! Found Property: " + pFeat.Value[pFeat.Fields.FindField("PROPID")]);
That means that your map service is fine, and that there is something wrong in the implementation ... In my code above, I used a Point that I created instead of a Feature from a Layer in a Map. That might be where your problem lies ...Hope this helps,-Kevin
