That is code to register an addin. The code for registering COM components is different.Imports System.ComponentModel
Imports System.Configuration.Install
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Imports System.IO
Imports System.Security.AccessControl
Public Class Installer1
Public Sub New()
MyBase.New()
'This call is required by the Component Designer.
InitializeComponent()
'Add initialization code after the call to InitializeComponent
End Sub
Public Overrides Sub Install(ByVal stateSaver As System.Collections.IDictionary)
Dim pRegSvr As New RegistrationServices
Try
MyBase.Install(stateSaver)
If Not pRegSvr.RegisterAssembly(MyBase.GetType().Assembly, AssemblyRegistrationFlags.SetCodeBase) Then
Throw New InstallException("COM registration failed. Some or all of the application classes are not properly registered in the ESRI component categories.")
End If
Catch ex As Exception
System.Windows.Forms.MessageBox.Show(ex.Message, "Install Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
Public Overrides Sub Uninstall(ByVal savedState As System.Collections.IDictionary)
Try
MyBase.Uninstall(savedState)
If Not pRegSvr.UnregisterAssembly(MyBase.GetType().Assembly) Then
Throw New InstallException("COM unregistration failed. Some or all of the application classes were not properly removed from the ESRI component categories.")
End If
System.Windows.Forms.MessageBox.Show(ex.Message, "Uninstall Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
End Class
