I have a question on data integrity, specifically between the interaction between AXF check-ins and changed domains & associated values within a database.
Specifically, say I have a domain for a field for three values, Alb : Albatross, Bir : Birdie, and Cho : Choke. I have let's say a feature class with a field that uses these values and has a bunch of records populated with Alb, Bir, or Cho.
Next, I check out an AXF for editing in ArcPad.
I then decide to change the Domains to A : Albatross, B : Birdie, and C : Choke. I also change the existing values of Alb, Bir, and Cho to A, B, and C respectively.
My question is, when I then check in the AXF (with let's say new features), what happens? It would attempt to check in values of Alb, Bir, and Cho which would not correspond to the new domain values. Would it also attempt to update the existing database of A, B, or C back to their old values as well?
Thanks in advance
