Hi, I want to get an extra explanation the reported errors below. The confusing here is that the polygon on ArcPad looks fine and close properly. Can anyone help?
1 out of 1 AXF files were processed. Here are the results:
* The selected layers in C:\Users\gdasgdbadmin\Desktop\yusuf\AF44064_afterSync\DataForArcPad\DBO_FieldworkGroup2_KC2_4_5K_gdasgdb.axf were successfully checked in, but one or more edits were skipped because the geodatabase reported an error. The first error reported is:
Polygon does not close properly
The following XML document lists all ArcPad edits that were replayed against the source geodatabase.
Please click the ? button and then click this report for more details about the XML format.
<?xml version="1.0"?>
<CHECKIN>
<CHANGE tablename="B_RECREATIONAL_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
<CHANGE tablename="B_INSTITUTIONAL_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
</CHANGE>
<CHANGE tablename="B_COMMERCIAL_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
<CHANGE tablename="B_BUILDINGS_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
<CHANGE tablename="B_BUILTUP_BUILDING_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
</CHANGE>
</CHANGE>
<CHANGE tablename="U_ELECTRICAL_STATION_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
<CHANGE tablename="U_COMMUNICATION_TOWER_A" oid="2134356" status="N" action="F" message="Polygon does not close properly">
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHANGE>
</CHECKIN>
