Hi all,
I'm having an issue with checking out features from an SDE database to .axf. Here's the deal:
I've got a feature class with a bunch of different subtypes in it, but when I export it the usual way (through the data manager toolbar, the way I've been doing it for months), some of the features just don't get exported. Usually its by subtype, so for instance, all the headwalls and plugs will export fine, but the inlets won't export at all. There are no definition queries, wierd symbology or form behavior that should be causing anything like this, and I can't see to figure out why some features export, and others refuse to. I've used different MXDs, applied / not applied custom forms, exported the entire feature class / just a small extent, nothing seems to affect it.
It had been working fine for months, and the trouble started when I deleted four fields from the feature class. They were just text fields that had no relationships or anything associated with them. If I export the feature class's features to a shapefile, I can then successfully export all the features, but of course can't use the custom forms anymore / check in edits to the SDE how I'd like to.
This happens with ArcPad 8 and 10, on different computers, using 9.3.1 to check out.
If anyone has run into an issue like this and gotten it fixed I'd love to hear from you!
Eric
