I have run into a weird check in issue using ArcPad 8, SP4 - ArcMap 9.3.1 SP2. This is a simple project with only one feature class being edited. Data was checked out using ArcPad Data Manager toolbar a new .axf with only that one layer. Staff then collected 61 new features, modified one, and was ready to check the data back in (data collected on Trimble GeoXT, running ArcPad 7.1.1). The "Get Data From ArcPad" window shows that 61 features were 'Added,' and 1 was 'Modified.'
See 1st attachement (screenshot).
I then open 'Get Data From ArcPad' window in ArcMap, select the .axf with edits, then select the feature class, click 'Check In.' I am not editing and get the window warning that I am about to check in without being in an edit sesson, click 'Yes,' and I get a report that:
"1 out of 1 AXF files were processed. Here are the results:
* There were no edits in the selected layers in G:\GIS_Data......"
See 2nd attachment (screenshot).
Nothing is then checked in into the fGDB and the 'Added' and 'Modified' window then will show that there are still edits to be checked in, no matter how many times I've tried it. I've done the check in routine several times now, some while editing, some while not. I've created a blank project with just that one layer and tried to check it back in, same results.
Anyone else seen this, and if so, figured out a work around or a cause for this issue???
Thanks.
