No TSIP Protocol option in ArcPad 10.0 GPS Preferences
844
04-25-2011 08:46 AM
SawyerScherer
Using a new Juno SC with new install of ArcPad 10.0.  Have a need to connect the Juno to my Trimble Pro XH.  Problem...no option exists in ArcPad to select the TSIP protocol in GPS Preferences.  I am only offered NMEA and SIRF.  What happened to TSIP?
Tags (3)
BrettBlack1
Which version are you running? I just loaded 10.0.2 on my PC and TSIP shows up in this version.
SawyerScherer
Intersting...TSIP was available on the version installed on my PC, but not the Juno.
Using Version 10.0 (Build 55) (I see that I need to download an ugrade already).  However, I was able to solve this today.  Very simple solution.  Found in Advanced Settings/Extensions that TSIP was not "checked" on.  Been a long-time arcPad 6 and 7 user for years and I'd never had to do this in those previous versions of ArcPad.
RolfBroch
Occasional Contributor II
Have you checked that TSIP is activated on the extension tab in advanced settings?
Rolf
SawyerScherer
Rolf
ThankYou Rolf.  That is the solution.
gabe
