Hello! I am trying to copy a new template that I made with the ArcPad Data Manager Tool in ArcMap. I've created my template and copied it over to my Trimble Unit but it isn't showing up when I open a new QuickProject. I've stored it in ProgramFile>ArcPad>Templates AND in My Documents neither place works when trying to open the Quick Project. Anyone have any ideas? Thanks!
Kris,
Can you list what version of ArcPad you're using, what device you're trying to connect to, and what the OS is on the device?
I found a couple of resources that might help out but I am not sure. Take a look at:
A New Way of Working with ArcPad - Templates - GeoMattix
and
Hi Adrian,
I figured it out. Thanks for the reply though! Much appreciated!
Kris,
Can you describe what you process you did to solve the issue?
The get data for arcpad tool put all files including the zip file into
it's own folder. I was mistakenly just copying this folder over. Once I
moved the ZIP file out from under this folder and put it in the correct
folder I was able to see my template.
Kris Cope
Farmington Electric Utility Systems
GIS Tech
505-599-8358 (Office)
505-306-1972 (Mobile)
kcope@fmtn.org
*This email should not be considered private communication. E-mail
correspondence is maintained in accordance with applicable provisions of
State law and may be considered public records. Public disclosure of your
communication may be required. Please call the number above If you intend
confidential or personal communication*
