I'm working with the Utility Network solutions for Sanitary Sewer and Water. I'm creating custom validation rules. I found only one validation rule came with the Utility Network solution for Sanitary Sewer ("Device - Check Pipe Connection"), and it uses error number 5001.
Is there an Esri reference for validation rule error numbers? Is there a recommended range of numbers to use for custom validation rules?
