Attempting workflow to pull contours from ArcGIS Pro and open them as working files in AutoCAD LT. After I convert the contours in ArcGIS Pro to a CAD file, AutoCAD LT opens the file, but incorrectly aligned with the AutoCAD basemap. The scale of the contours is also too small - appears to be at a scale factor of 1/12.
My steps are as follows:
1.) Set Up AutoCAD LT Drawing as new, acadlt.dwt template, with units: architectural, inches. I've also tried feet. Geo > set location from map > address > GIS Coordinate System > Drawing Unit: Inches > place at (0,0) ; 90deg North. Save File, basemap.dwg
2.) In ArcGIS Pro: Export contour lines w/ "Export to CAD" Tool;
Unit: US-SurveyFT, Output Type - DWG version 2018; Ignore Paths in Tables, Seed File: basemap.dwg; Match Output Coordinate System, Save File: contour lines.dwg
3.) In AutoCAD LT: Open contour lines.dwg > contours are too small, improperly located, and not aligned with anything on the basemap.
