Calcite + ArcGIS Site / Hub
681
08-18-2023 07:21 AM
MathieuVillemont
Is it possible to use Calcite components or icons inside ArcGIS Site/Hub ?
KlaraSchmitt
Hello @MathieuVillemont,
You are correct. It is not in ArcGIS Enterprise Sites yet. It will be available in the Text Card in 11.2.
KlaraSchmitt
You can use select any of the calcite components, including the calcite icons, in Hub via our Text Card. You just have to switch to Edit in HTML first and then you can paste in the component code.
Edit 02/26/24: It turns out I was incorrect when I stated that any of the calcite components could be used. For a list of supported components see: https://doc.arcgis.com/en/hub/sites/add-text-and-images.htm#ESRI_SECTION1_3E6FBF82D17C476D9A7AA6F432... in Hub documentation or https://enterprise.arcgis.com/en/sites/latest/sites/add-text-and-images.htm#ESRI_SECTION1_3E6FBF82D1... in Enterprise Sites documentation.
MathieuVillemont
Thanks @KlaraSchmitt.
It works well in Hub, however not in Site. I'm having Portal 10.8.1. Maybe a newer version would fix that ?
KlaraSchmitt
StefanUseldinger
Occasional Contributor II
Works great in 11.2
