Calcite Maps - Shell Panel
2238
10-23-2021 06:20 AM
DerrickLim
New Contributor II
Hi esri community! I am trying currently trying to use the calcite-action-bar to open/close a calcite-panel using calcite-flow. So far i do not have much luck in doing so. Is there a button i need to create in the action bar container and write a JS code for this sort of interactivity? if so, how? See below for the script under the <body>....</body> section of my html script:-
<body class="calcite-theme-light">
  <div class="calcite-shell-container">
    <calcite-shell content-behind calcite-hydrated>
        <calcite-shell-panel slot="primary-panel" position="start" expand>
          <calcite-action-bar slot="action-bar" class="calcite-theme-dark" >
            <calcite-action text="Add" icon="plus"></calcite-action>
            <calcite-action text="Save" icon="save"></calcite-action>
            <calcite-action text="Layers" icon="layers"></calcite-action>
          </calcite-action-bar>
          <calcite-flow id="layer-list-flow" calcite hydrated>
            <calcite-panel heading="Layers" intl-back="Back" dismissible calcite hydrated>
                <calcite-tip heading="No layers" non-dismissible calcite-hydrated>
                    <p>Add layers to your map and they will appear here</p>
                </calcite-tip>
            </calcite-panel>
          </calcite-flow>
        </calcite-shell-panel>
   </calcite-shell>
  </div>
</body>
Thank you!
BenElan
Hi @DerrickLim, I apologize for the delayed response. In the sample below, clicking on the "info" action will toggle the panel. Let me know if you have any additional questions!
https://codepen.io/benesri/pen/JjywgXy?editors=1010
BenElan
DerrickLim
New Contributor II
Hi Ben, no worries and thanks for the solution. It works! Also, do you have any idea how to encapsulate shell panels into one single panel when i click the other tabs on the left? Currently mine is resulting with two panels with the action button enabled which is not what i am looking for. thanks 
BenElan
I'm not sure how you set that up, but if you have two separate panels then you should make sure to collapse one when you open the other.
BenElan
To follow up on this question, I just released a tutorial that will help with this workflow:
https://developers.arcgis.com/calcite-design-system/tutorials/create-a-mapping-app/
