And here is a link to Intel's page that talks about specific i3 processors
Intel® Core™ i3 Processors
It does look like they are (at least?) dual core. i think for Pro at least, a good graphics card will be important.
Whether the software will run well or not is a bit of a subjective, and it will also depend on what you are doing. We have much older machines that run both fine for our needs, but we don't do much/any 3D. I do developement and quite a bit of processing on them, but for my machines, I do not do as much editing and straight map making anymore. Although older machines (8+ yrs), when we buy one for the office we buy the best we can afford and that follows our office guild lines at the time (GIS machines tend to be a bit beefier, usually Del Precisions), so I tend to keep and use them for as long as I can. With that said, some processes on newer VM machines do run faster since they do have more processing power.
But as Dan mentioned, test any existing machine if you can, or check the manufactures/machines spec to see if they hold up against the requirements. If new machine, get what you can afford. Another thing to try, if it is an option with you licensing and work needs, install it and test it out. Again, what you do will determine if it is adequate for your purposes or not.
