I come back to you as it seems that some .js have changed in the shortlist template and it made my logos disappeared!
I added the previous code around the line 2110 of the new main.js but it is obviously not enough.
Thank you in advance
Matthieu
Hi Matthieu,
Do you have a link to your shortlist that we can take a look at? Your custom code should work fine in the updated versions of Shortlist, but we can help you take a look and see whats going on.
-Mark
I am sincerely sorry to say that I bothered you for nothing.
The code works perfectly fine, I made a mistake, I was working in a file and testing an other!
Thank you.
Matthieu
