Adding an email link to hosted Story Map
4401
07-17-2014 11:50 AM
deleted-user-eecV1RPyUfl1
I've been trying to change the "header top right link" in the Application Settings from a website link to an email link, but each time I save the changes the application drops an "http://" in front of the "mailto:" which causes the link to go back to a website.  Is there any way to override this, short of downloading the app which I'd prefer not to do?
I've also tried to edit the html code but can't seem to retain changes made there either.  Thanks!
GregoryL_Azou
Occasional Contributor III
Sorry about the issue. I opened an issue for you so you can track it's status.
Until it is resolved I gave you a workaround there that require to use the downloadable.
GregoryL_Azou
Thank you very much Gregory.  Would I have to rebuild the project from the beginning as well as host it?
GregoryL_Azou
You are welcome.
You don't have to rebuild the project, you just have to download it from GitHub and edit index.html to reference your MapTour application ID, please see the instructions.
But yes you would have to host it, Dropbox is a very good option if you don't have access to a webserver, you may need to enable Dropbox the application hosting feature.
