Allow users to add comments in Story Maps or Web Maps
5625
09-15-2017 12:00 PM
BrianLedder1
I am creating a story map to display the status of water supply tanks for a community in Jamaica. I have a web map with point locations of each tank and I'd like to allow users to leave comments under each one. It doesn't seem like the functionality for leaving comments is available in Story Maps or in Web Maps unless I am not able to find it. Is there a way to allow users to leave comments? I've looked at the "crowdsoucred" template but I want users to leave comments under already existing points, not have a point created for each comment.
Thanks for your help!
MarkCooney
Occasional Contributor III
Hi Brian,
Have a look at the Crowdsource Polling app: Crowdsource Polling | ArcGIS for Local Government .  You could create one of these and embed in a Story Map.
Mark
MarkCooney
Hi Brian,
Mark
BrianLedder1
Thanks! It looks like that will be a good option. But now I have a follow up question.
I imported my web map with two point file feature layers and I see under the options tab I need to select a "polling feature layer". But this is greyed out and I cannot select anything.
MarkCooney
I am not actually very familiar with that app, you may have better luck asking here: https://community.esri.com/community/gis/web-gis/arcgisonline
BrianLedder1
Ok, Thank you
