Can you add a legend to a map within a Cascade story map?
2324
08-01-2016 05:18 AM
KatyAppleton1
Occasional Contributor II
I love the Cascade template, but the maps I use within it could do with having a visible legend. I can't see this in the options - am I missing something?
OwenGeo
Esri Notable Contributor
Hi Katy,
Thanks for submitting feedback on Cascade. We have not added a legend feature yet but have it on our list to add in a future release.
When creating story maps, we do recommend trying to use very simple maps that don't require a legend or that can be easily explained in the story narrative; however, we of course realize that is not always possible.
For now, the best option is to either take a screenshot of the legend in the map viewer or create your own graphic and add that as an image to your story. This can be done as an in-line image in a sequential section or in the immersive panel if the map is in an immersive section.
Owen
Owen Evans
OwenGeo
Hi Katy,
Owen
Owen Evans
KatyAppleton1
Thanks Owen. My map is pretty simple, I would just like to differentiate between three different coloured symbols. A screenshot in the immersive panel is a good workaround for now.
Katy
DanPatterson_Retired
Do the maps you are using already have a legend? This link suggests that you prepare the content prior to making the Cascade story map... otherwise I see no reference to making a legend after the fact
Story Map Cascade Tutorial | Story Maps
EDIT
too late... I will leave the link to the tutorial
KatyAppleton1
Thanks anyway, Dan!
