Hi there,
I have a cascade story with an immersive section. I want to have the same view of a map change as the user scrolls down which turns on/off different layers. However, when I choose vertical transition there is a part of the scroll where everything disappears and only the basemap is shown between view A and view B that I have set up. This ruins the seamless affect and general looks a bit clunky. I'm not sure why it is doing this? If I save view A and view B as two separate maps the transition is fine, it only seems to be a problem when scrolling between different views of the same map.
I appreciate that is a bit confusing - what I'm trying to achieve is what the "Tree cover, biomass, and diversity" section of the below storymap acts like:
https://storymaps.esri.com/stories/2019/anthropocene/3-forests/index.html
Any help would be appreciated!
