Crowdsource Beta Feedback
2735
15
07-20-2016 05:16 PM
SarahZaleski
After working with the crowdsource storymap beta version for a little, here are a few ideas that I think would be improvements.
  1. Email notification of a submission to owner
  2. Ability to delete submissions
  3. Ability to hide submissions (make data not readable by anyone)
  4. Have location symbol change color when selected.
SarahZaleski1
Sounds good!
Thanks!
SarahZaleski1
I was just trying to use the crowdsource story map we have and noticed a few issues:
- initial load time was slow
- locate me does not seem to work, and it brings up a map with the wrong location.
- the text field activation is slow, it takes quite a bit of time before active.
Thanks!
Sarah
StephenSylvia
Sarah,
Thanks for your feedback. Could you provide us with a little more information so we can help optimize the app in the future.
1. What device, browser, and internet connection (ethernet, wifi, cellular) are you using? How many points are in your crowdsource story? Do you have a public link you can share to your story?
2. In most cases the location provided by the browser is determined by your internet service provided. If you are using a personal internet connection at home or a cellular connection, your location should be pretty accurate. In some cases, ISP's do not share correct information for privacy reason. If you are on a corporate network, your location may be less reliable due to how your company sets up their network. For example, I work in a small regional office in VA, but our headquarters is in CA which is where the connection is registered so it sometimes looks like my location is in CA. How far off is the location that is provided?
3. Which text field activation? Do you mean clicking on a text input in the participate form and the time it takes before you can start typing?
SarahZaleski1
My answers are below.
1. Android on cellular network. There are 55 points in the story. Here is the map http://arcg.is/29ETvMB
2. I was on my phone cellular network which in the past has been accurate using the Locate Me feature on the app. But this time the Locate Me did not seem to behave like other locate me features, or as it did in the past. The location was put on 6th Ave while I was on 10th.
3. The Title text field in the participation form has a delay in response. After the picture uploads, when you tap Title to enter text it has a long delay. This could be an issue with people wanting to interact, they may tire of the wait.
Thanks!
StephenSylvia
Thanks for your response. We'll try to continue optimize the app as much as we can for these scenarios. A couple notes that may help. The accuracy the we can provide through the locate me feature is limited to what your phone will provide. Here are a couple tips that may improve accuracy:
  • Make sure you have given your browser permission to access your phone's location (IP address location is much less accurate)
  • On Android, make sure you have your phones location's setting set to "high accuracy."
  • Due to how GPS and other location signals work, location will be most accurate outside with a clear open sky. If you have tall buildings/trees around you, the signal will bounce off these walls causing your accuracy to decrease.
The delay to enter text after you pick a photo is due to the photo having to load into the browser and reading its location. Most phones limit how much processing power it will provide to the web browser which can cause the "stall" in the user interaction momentarily until it finishes.
SarahZaleski1
I had another thought about potential additions to the crowdsource map template. It would be nice to get some sort of comment/feedback on the map as people use it, within the application. This could be through something like a  "rate the app" or  email link.
Sarah
