Hosted Shortlist Story Map Not Displaying
1045
10-24-2016 08:25 AM
EthanUnzicker1
New Contributor III
I'm self-hosting a Shortlist so I customize a few things. However the application won't fully load and just displays the broken image icon.
Here's a link to where it should be displaying, but it's not.
Heres a link to the ArcGIS hosted version, which works just fine.
Here's my index.html `<!DOCTYPE html>
    <meta name="apple-mobile-web-app-capable" content="yes">     <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">      <link type="image/ico" rel="shortcut icon" href="https://community.esri.com//resources.esri.com/favicon.ico">     <link type="image/ico" rel="icon"  href="https://community.esri.com//resources.esri.com/favicon.ico">      <!--         To correctly reference your Shortlist in search engine:          - create and fill out extensively an ArcGIS Online item that link to your final application          - edit the following four tags as well as the title tag above on line 4     -->     <meta name="description" content="This story map was created with the Story Map Shortlist application in ArcGIS Online.">      <!-- Facebook sharing -->     <meta property="og:type" content="article"/>     <meta property="og:title" content="Story Map Shortlist"/>     <meta property="og:description" content="This story map was created with the Story Map Shortlist application in ArcGIS Online."/>     <meta property="og:image" content="resources/common/icons/esri-globe.png"/>      <!--         This application is released under the Apache License V2.0 by Esri http://www.esri.com/         Checkout the project repository on GitHub to access source code, latest revision, developer documentation, FAQ and tips         https://github.com/Esri/shortlist-storytelling-template-js     -->      <script type="text/javascript">         //-------------------------------------------------------------------------------------------         //   Application configuration (ignored on ArcGIS Online, Portal and during development)         //-------------------------------------------------------------------------------------------         var configOptions = {             // Enter an application ID created through the Shortlist builder             appid: "b8d0e8bea0a24152bb472b3ab9540a59",             // Optionally to secure Shortlist's access, use an OAuth application ID (example: 6gyOg377fLUhUk6f)             // User will need to sign-in to access the viewer even if your application is public             oAuthAppId: "",             // Optionally to be able to use the appid URL parameter, configure here the list of application author             //  whose application are allowed to be viewed by this Shortlist deployment             // This is the Portal username of the Shortlist owner (e.g. ["user1"], ["user1", "user2"])             authorizedOwners: ["*"]         };         // Optionally sharing and proxy URLs can be configured in app/config.js. This is only required         //  when the webmap is not hosted on ArcGIS Online or a Portal for ArcGIS instance and the application isn't deployed as /home/Shortlist/ or /apps/Shortlist/.         // Optionally Bing Maps key, Geometry and Geocode service's URLs can be configured in app/config.js. This is only required         //  if the Organization or Portal for ArcGIS instance default configuration has to be overwritten.     </script>      <!--          Edit below at your own risk      -->      <script type="text/javascript">         var app = {             version: '2.0.1',             pathJSAPI: '//js.arcgis.com/3.18/'         };     </script>  </head> <body class="claro">     <style>         /* CUSTOM CSS RULES */     </style>      <!-- Builder top panel is injected here -->     <div id="builderPanel" class="hide mainViewAboveMap"></div>      <!-- Header -->     <div id="header" class="mainViewAboveMap">         <!-- Desktop header -->         <div id="headerDesktop" aria-hidden="true">             <div class="rightArea">                 <div class="linkSocialContainer">                     <button type="button" class="switchBuilder btn btn-xs btn-primary" tabindex="-1"></button>                     <span class="linkContainer"></span>                     <span class="shareBtns">                         <i class="shareIcon blackHover share_facebook icon-facebook-squared" title="Share on Facebook"></i>                         <i class="shareIcon blackHover share_twitter icon-twitter" title="Share on Twitter"></i>                         <i class="shareIcon blackHover share_bitly icon-link" title="Share a short link"></i>                     </span>                 </div>                 <div class="logoContainer">                     <table class="logoContainerInner">                         <tr>                             <td class="logoWrapper">                                 <a class="logoLink" target="_blank" tabindex="-1">                                     <img class="logoImg"/>                                 </a>                             </td>                         </tr>                     </table>                 </div>             </div>             <div class="textArea">                 <h1 class="title" tabindex="0"></h1>                 <h2 class="subtitle" tabindex="0"></h2>             </div>             <div class="builder-mask"></div>         </div>     </div>      <!-- Tab/bullet navigation bar -->     <div id="nav-bar" class="mainViewAboveMap"></div>      <!-- Content -->     <div id="contentPanel" class="mobileView">         <div id="mobileBookmarksCon">             <div id="mobileBookmarksToggle"><p id="mobileBookmarksTogText"></p></div>             <div id="mobileBookmarksDiv"></div>         </div>          <div id="mainStagePanel">              <div class="needsclick" id="map">                 <div id="search"></div>             </div>             <div id="builderLandingOverlay"></div>             <!--<div id="builderQuotes"></div>-->             <div id="builderLanding"></div>         </div>         <!--<div id="testPanel" class="testPanel"></div>-->          <!-- Mobile View -->         <div id="mobileThemeBar">             <div id="navThemeLeft">                 <div class="detail-btn ion-chevron-left" style="outline: none;"></div>             </div>             <div id="navThemeRight">                 <div class="detail-btn ion-chevron-right" style="outline: none;"></div>             </div>             <div id="mobileThemeSliderContainer"  class="swiper-container">                 <div id="mobileThemeBarSlider" class="swiper-wrapper"></div>             </div>         </div>         <div id="mobilePaneList">             <ul id="mobileList" class="mobileTileList" data-role="listview"></ul>             <div class="noFeature">                 <span class="noFeatureText">                     <!--There are no features within the current map extent.                     Click on the home button to return to the initial extent.-->                 </span>             </div>         </div>         <div id="mobileSupportedLayersView"></div>          <div id="mobilePaneFader"></div>      </div>     </div>      <!-- Loading -->     <style>         #loadingOverlay {             position: absolute;             top: 0;             left: 0;             z-index: 1100;             width: 100%;             height: 100%;             overflow: hidden;             background-color: #E5E5E5;             -webkit-box-shadow: inset 0px 0px 82px 19px rgba(0,0,0,0.3);             -moz-box-shadow: inset 0px 0px 82px 19px rgba(0,0,0,0.3);             box-shadow: inset 0px 0px 82px 19px rgba(0,0,0,0.3);         }          @keyframes fadein { from { opacity: 0; } to { opacity: 1; } }         @-moz-keyframes fadein { from { opacity: 0; } to { opacity: 1; } }         @-webkit-keyframes fadein { from { opacity: 0; } to { opacity: 1; } }         @-ms-keyframes fadein { from { opacity: 0; } to { opacity: 1; } }         @-o-keyframes fadein { from { opacity: 0; } to { opacity: 1; } }          @keyframes fadeout { from { opacity: 1; } to { opacity: 0; } }         @-moz-keyframes fadeout { from { opacity: 1; } to { opacity: 0; } }         @-webkit-keyframes fadeout { from { opacity: 1; } to { opacity: 0; } }         @-ms-keyframes fadeout { from { opacity: 1; } to { opacity: 0; } }         @-o-keyframes fadeout { from { opacity: 1; } to { opacity: 0; } }          #loadingOverlay.fadeOut {             -webkit-animation: fadeout 1.1s;             -moz-animation: fadeout 1.1s;             -ms-animation: fadeout 1.1s;             -o-animation: fadeout 1.1s;             animation: fadeout 1.1s;             -webkit-animation-fill-mode:forwards;             -moz-animation-fill-mode:forwards;             animation-fill-mode:forwards;         }          #loadingIndicator {             position: fixed;             top: 50%;             left: 50%;             z-index: 1101;         }          .loadingIndicator {             margin-left: -17px;             margin-top: -20px;         }          /*          * Inlining of resources/tpl/viewer/font/font/css/fontello.css and animation.css          */         @font-face{font-family:'fontello';src:url(resources/tpl/viewer/font/font/fontello.eot?22851922);src:url(resources/tpl/viewer/font/font/fontello.eot?22851922#iefix) format("embedded-opentype"),url(resources/tpl/viewer/font/font/fontello.woff?22851922) format("woff"),url(resources/tpl/viewer/font/font/fontello.ttf?22851922) format("truetype"),url(resources/tpl/viewer/font/font/fontello.svg?22851922#fontello) format("svg");font-weight:400;font-style:normal}[class^="icon-"]:before,[class*=" icon-"]:before{font-family:"fontello";font-style:normal;font-weight:400;speak:none;display:inline-block;text-decoration:inherit;width:1em;margin-right:.2em;text-align:center;font-variant:normal;text-transform:none;line-height:1em;margin-left:.2em}.icon-spin1:before{content:'\e800'}.icon-link:before{content:'\e801'}.icon-facebook-squared:before{content:'\e802'}.icon-twitter:before{content:'\e803'}.animate-spin{-moz-animation:spin 2s infinite linear;-o-animation:spin 2s infinite linear;-webkit-animation:spin 2s infinite linear;animation:spin 2s infinite linear;display:inline-block}@-moz-keyframes spin{0%{-moz-transform:rotate(0deg);-o-transform:rotate(0deg);-webkit-transform:rotate(0deg);transform:rotate(0deg)}100%{-moz-transform:rotate(359deg);-o-transform:rotate(359deg);-webkit-transform:rotate(359deg);transform:rotate(359deg)}}@-webkit-keyframes spin{0%{-moz-transform:rotate(0deg);-o-transform:rotate(0deg);-webkit-transform:rotate(0deg);transform:rotate(0deg)}100%{-moz-transform:rotate(359deg);-o-transform:rotate(359deg);-webkit-transform:rotate(359deg);transform:rotate(359deg)}}@-o-keyframes spin{0%{-moz-transform:rotate(0deg);-o-transform:rotate(0deg);-webkit-transform:rotate(0deg);transform:rotate(0deg)}100%{-moz-transform:rotate(359deg);-o-transform:rotate(359deg);-webkit-transform:rotate(359deg);transform:rotate(359deg)}}@-ms-keyframes spin{0%{-moz-transform:rotate(0deg);-o-transform:rotate(0deg);-webkit-transform:rotate(0deg);transform:rotate(0deg)}100%{-moz-transform:rotate(359deg);-o-transform:rotate(359deg);-webkit-transform:rotate(359deg);transform:rotate(359deg)}}@keyframes spin{0%{-moz-transform:rotate(0deg);-o-transform:rotate(0deg);-webkit-transform:rotate(0deg);transform:rotate(0deg)}100%{-moz-transform:rotate(359deg);-o-transform:rotate(359deg);-webkit-transform:rotate(359deg);transform:rotate(359deg)}}      </style>     <div id="mobileBuilderOverlay"></div>     <div id="loadingOverlay"></div>     <div id="loadingIndicator" class="loadingIndicator">         <img src="resources/tpl/viewer/icons/loading-light.gif" />     </div>     <div id="loadingMessage"></div>      <!-- Share dialog -->     <div class="modal fade shareDialog" id="shareDialog" role="dialog" data-backdrop="static" tabindex="-1"></div>      <!-- Builder views are injected here -->     <div id="builder-views"></div>      <!-- Fatal error box -->     <div id="fatalError">         <table border="0">             <tr>                 <td width="70px" align="center" id="fatalError-icon"></td>                 <td id="fatalError-msg">                     <b class="error-title"></b>                     <p class="error-msg"></p>                 </td>             </tr>         </table>     </div>      <script type="text/javascript" src="app/main-config.js"></script>      <script type="text/javascript">         require(["dojo/topic"], function(topic) {             // The application is ready             topic.subscribe("tpl-ready", function(){                 /* */             });         });     </script> </body>
AdrianWelsh
MVP Honored Contributor
Hi Ethan,
I clicked on the first link and it came up just fine.
So did the second link.
AdrianWelsh
Hi Ethan,
EthanUnzicker1
New Contributor III
Well true enough it's working now. Must have been a server error on my side. Thanks mate!
Cheers
AdrianWelsh
Sometimes it takes a while to "sync" or whatever it needs to do. Waiting 15-30 minutes works well, I have found (or hopefully less time than that).
