Hi again Steven,
Thank you for your reply yesterday. I was a bit confused, so I'm attaching a Word file with some screenshots of my map(s), and comments/questions. I wonder if you can explain to me what exactly you meant by 'map editor' after seeing what I'm working on. Please let me know if my questions make sense, and if you can direct me further.
Thank you very much. I really appreciate your help!
Suzanne
To: Suzanne Luhr <suz_wyo@yahoo.com>
Sent: Thursday, January 12, 2017 12:17 PM
Subject: Re: - Re: Map Home location?
#yiv6220763308 * #yiv6220763308 a #yiv6220763308 body {font-family:Helvetica, Arial, sans-serif;}#yiv6220763308 #yiv6220763308 h1, #yiv6220763308 h2, #yiv6220763308 h3, #yiv6220763308 h4, #yiv6220763308 h5, #yiv6220763308 h6, #yiv6220763308 p, #yiv6220763308 hr {}#yiv6220763308 .yiv6220763308button td {}
reply from Stephen Sylvia in Story Maps - View the full discussionWhen using Map Series, the home location is set by the initial extent of the webmap (the extent that was saved from the ArcGIS Online map editor. If you panned your map and saved again in the editor, the Map Series app would use that extent as the home extent. Another possibility if you are using multiple maps, you may have checked the "synchronize map locations" option, in which case, the home extent uses the extent of the first map for all the maps.
Reply to this message by replying to this email, or go to the message on GeoNet |
Start a new discussion in Story Maps by email or at GeoNet |
Following Re: Map Home location? in these streams: Inbox |
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
