Map Home location in Map Series?
1316
6
01-11-2017 01:58 PM
SuzanneLuhr
How do I set my map home location in the app, after the map is completed and an app created from it? It was set correctly, then changed!
StephenSylvia
Which app are you using: Apps | Story Maps?
SuzanneLuhr
Hi, This is a Story Map Series app. It worked fine until yesterday, and I'm not sure what I might have done to change the extent, but although the scale is the same, the map shifted. Thanks!
StephenSylvia
When using Map Series, the home location is set by the initial extent of the webmap (the extent that was saved from the ArcGIS Online map editor. If you panned your map and saved again in the editor, the Map Series app would use that extent as the home extent. Another possibility if you are using multiple maps, you may have checked the "synchronize map locations" option, in which case, the home extent uses the extent of the first map for all the maps.
SuzanneLuhr
Hi again Steven,
Thank you for your reply yesterday. I was a bit confused, so I'm attaching a Word file with some screenshots of my map(s), and comments/questions. I wonder if you can explain to me what exactly you meant by 'map editor' after seeing what I'm working on. Please let me know if my questions make sense, and if you can direct me further.
Thank you very much. I really appreciate your help!
Suzanne
To: Suzanne Luhr <suz_wyo@yahoo.com>
Sent: Thursday, January 12, 2017 12:17 PM
Subject: Re: - Re: Map Home location?
#yiv6220763308 * #yiv6220763308 a #yiv6220763308 body {font-family:Helvetica, Arial, sans-serif;}#yiv6220763308 #yiv6220763308 h1, #yiv6220763308 h2, #yiv6220763308 h3, #yiv6220763308 h4, #yiv6220763308 h5, #yiv6220763308 h6, #yiv6220763308 p, #yiv6220763308 hr {}#yiv6220763308 .yiv6220763308button td {}
GeoNet
reply from Stephen Sylvia in Story Maps - View the full discussionWhen using Map Series, the home location is set by the initial extent of the webmap (the extent that was saved from the ArcGIS Online map editor. If you panned your map and saved again in the editor, the Map Series app would use that extent as the home extent. Another possibility if you are using multiple maps, you may have checked the "synchronize map locations" option, in which case, the home extent uses the extent of the first map for all the maps.
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Story Maps by email or at GeoNet
Following Re: Map Home location? in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
StephenSylvia
Yes, editing the layer popups in the web map is the "map editor" I was referring to. When you click "save" in the editor, it will save the current extent of the map as the home extent in the app. The map series app will just center the map. To offset it for the description, just move offset it in the map editor and save it again.
To your last question about clicking on a point to change the tab, it is not possible in the hosted version of the app. If you are willing to download the app and add a little bit of JavaScript, you can get it to work. Here's an example The World is Full of Circles | Travel | Smithsonian (Look at the last "map" tab).
SuzanneLuhr
Thanks Stephen,
It didn't work the first time, but I will keep trying! And I would like to experiment with downloading it to our server. We have not done that, but I'd like to try it. Thanks for the example.
Suzanne
Sent: Friday, January 13, 2017 9:41 AM
#yiv7529695156 * #yiv7529695156 a #yiv7529695156 body {font-family:Helvetica, Arial, sans-serif;}#yiv7529695156 #yiv7529695156 h1, #yiv7529695156 h2, #yiv7529695156 h3, #yiv7529695156 h4, #yiv7529695156 h5, #yiv7529695156 h6, #yiv7529695156 p, #yiv7529695156 hr {}#yiv7529695156 .yiv7529695156button td {}
GeoNet
reply from Stephen Sylvia in Story Maps - View the full discussionYes, editing the layer popups in the web map is the "map editor" I was referring to. When you click "save" in the editor, it will save the current extent of the map as the home extent in the app. The map series app will just center the map. To offset it for the description, just move offset it in the map editor and save it again. To your last question about clicking on a point to change the tab, it is not possible in the hosted version of the app. If you are willing to download the app and add a little bit of JavaScript, you can get it to work. Here's an example The World is Full of Circles | Travel | Smithsonian (Look at the last "map" tab).
