I am using the Short List Beta Story Map to show construction projects.
I started with using an ArcGIS Map Service in a Web Map. This allowed me to specify what fields in the Feature Layer I wanted to use, but once the Short List wizard completed it created a new web map with a copy of my data that was no longer editable which will be a problem as we want to edit and delete items.
I then changed my approach to use a CSV uploaded to a web map using the Short List schema. This allows me to remove the layer in the web map and then re-import the CSV to update the data.
This latter option seems to work pretty well for updating the points but has some limitations in that I can't edit the text or add links or format the text once I load the CSV.
How are others working around this situation?
I understand that I can download a copy of the older Short List app and customize it more, but my preference would be to to use AGOL to host it.
Mele
