Shortlist - Tab name multuple occurences
423
06-08-2017 09:52 AM
EricHung
When setting up my csv file in the template format, is it possible to have multiple tab names for one location? For example, if I had a location that fell under the tabs "Day" and "Night", would it be possible to use a delimiter and have both Day, Night in the same Tab_Name box and have them be in both tabs in the published storymap?
RupertEssinger
Hi Eric, that's not supported. You would have to duplicate the record so that there are two records, one for each of the tabs you want the place to appear under. This gets requested in terms of having an All tab in a Shortlist. But there may be cases where you want a place to appear in two (or more tabs): that's unusual for Shortlists and not supported in the design. Note that if you want some points or other features to appear on the map in all tabs but not as places in the tabs, you could add those into the web map used in your Shortlist as supporting layers.
Rupert
RupertEssinger
Rupert
