Sure...here you go.
Jeff
Jeff,Looks like the issue with your shapefile was due to the projection it happened to be in. BAO is very finicky with projections and looks your shapefile was in AD_1983_StatePlane_North_Carolina_FIPS_3200_Feet. I used the Project GP tool to create a version in GCS_North_American_1983 and it uploaded fine into BAO and I could run a report on it. I have attached it in a .zip attached so give it a try and see if cooperates for you.Regards,Jason R.
