Points are not showing in map when data is versioned
1158
04-19-2022 08:32 AM
FiorellaRodriguez
Hello,
I have an issue with versioning. This happened after we upgraded AGE from 10.8.1 to 10.9.1
Enviroment:
AGE 10.9.1 federated
ArcGIS Pro 2.9.2
EGDB Branch versioned
This is only happening with 2 features classes in different datasets. All other features versioned are working fine.
Problem:
The feature layer is not showing points, it cannot draw them in the map, however in the attribute table it does show all elements (around 12000). As soon as we unregistered as versioned all point show in the map, and then disappeared when we registered as versioned. We repaired geometry and tried again with the same behavior.
Does anyone have any suggestions?
Thank you
BillFox
MVP Frequent Contributor
Is copying all the features into a new layer (temp...X) an option for you?
Then delete the bad one and copy the temp one as the same name.
Then register as versioned.
BrandonCranfield
New Contributor II
Running into the same issue.
AGE 11.1 Federated
ArcGIS Pro 3.1.3
EGDB Branch Versioned
Source data from SQL Server 2019 DB
Behavior: Primary key originally set to OID. Once Branch Versioning is enabled on the dataset, it automaticaly creates and sets the primary key to GDB_ARCHIVE_OID. Resetting the primary key to OID produces a separate error.
Same result with viewable point geometry. This is not rectified unless the dataset is unregistered as versioned.
RitaTaylor
New Contributor II
Same here. I have to reconcile after I create each point to see it. The extra step is tiresome after every edit.
Enterprise 10.9.1
Federated
Address Management Solution Branch Versioning
SQL Server 2019
