Show some of the coordinates.
Use the Excel to Table tool to create a featureclass table
Add that table as an event layer, then save it as a geodatabase featureclass and make sure you define its coordinate system correctly.
And as a tip... don't add a basemap first, add your data to an empty dataframe (if using arcmap) or map (ArcGIS pro)
basemaps can be added after
