check the raster properties, and report the extent so that the extent can be compared with what the projection is supposed to be.
Add this layer to a new data frame... Do NOT add a base map... check the properties of the data frame
Continue to add other layers.
If the extent and projection information in step 1 aren't good, then there are other things that need to be done
