I need define a projection system for the county map in Utah. I will first define counties.shp files by selecting a predefined geographic coordinate system and then the UTMutah projection. A custom coordinate system, UTMutah has the following parameter values. I need display XY data of Utah hospital, but even if I use the same projection UTMutah as counties.shp. They are far away each other, not correctly in the same spatial extent. I attached the counties.shp and hospital cvs data. Could you please let me know which step I am getting wrong? Thanks.
Projection: Transverse_Mercator
False_Easting: 500000.000000
False_Northing: 0.000000
Central_Meridian: -111.000000
Scale_Factor: 0.999600
Latitude_Of_Origin: 0.000000
Linear Unit: Meter (1.000000)
Geographic Coordinate System: GCS_North_American_1983
Angular Unit: Degree (0.017453292519943295)
Prime Meridian: Greenwich (0.000000000000000000)
Datum: D_North_American_1983
Spheroid: GRS_1980
Semimajor Axis: 6378137.000000000000000000
Semiminor Axis: 6356752.314140356100000000
Inverse Flattening: 298.257222101000020000
